Replacin B-Pipe, Bolts Rusted over question (Pics)
Old May 17, 2007 | 09:07 AM
imadigitalgod's Avatar
Default Replacing B-Pipe, Bolts Rusted over question (Pics)
RIght now I am in the process of replacing my b-pipe. I am going to take this to a shop to have them remove the bolts but it looks really rusted over. Would I need to get a new cat also? it seems to have taken over the whole thing.
Below is the joint between my cat and my b-pipe(the longest exhaust pipe).
Any advice is welcome
This is on a 4dr 99 civic EX
Old May 17, 2007 | 09:21 AM
EG2 SiR's Avatar
Default Re: Replacing B-Pipe, Bolts Rusted over question (imadigitalgod)
You could try a penetrating fluid and tapping it with a hammer to try to break it free, but it looks like you may need to grind/drill/replace the nuts and bolts.
Old May 17, 2007 | 09:38 AM
EG2Driver's Avatar
Default Re: Replacing B-Pipe, Bolts Rusted over question (EG2 SiR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG2 SiR &raquo;</TD></TR><TR><TD CLASS="quote">you may need to grind/drill/replace the nuts and bolts.</TD></TR></TABLE>
thats what i did on my old 91 Protege. It'll come appart, just make sure the flanges are sealing right and you're good to go.
Old May 17, 2007 | 09:49 AM
Default Re: Replacing B-Pipe, Bolts Rusted over question (DeadEnd9009)
alright well, i figured out a way to steady the whole pipe and i finally got them off with a breaker bar...except the nuts are stuck inside the bolts now. anyone now how to get those out?
I need the 14mm socket to take the other nut off but its out of service at the moment sicne its stuck in there
Old May 17, 2007 | 09:54 AM
instructor74's Avatar
thread it back on the bolt a little way an tap the socket with a hammer until it come loose.
Old May 17, 2007 | 09:55 AM
sicones's Avatar
Default Re: Replacing B-Pipe, Bolts Rusted over question (instructor74)
Didn't we just go over this
https://honda-tech.com/zerothread?id=1985723
Bring it to a shop if you're that incompetent
Old May 17, 2007 | 10:05 AM
rokwilder1's Avatar
save yourself the time and just cut the bolts off. Get new ones, they are cheap and it will save you the trouble in the future. Just did it myself.
Lifting up a lowered car is a b*tch!
Old May 17, 2007 | 10:18 AM
Default Re: (rokwilder1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rokwilder1 &raquo;</TD></TR><TR><TD CLASS="quote">save yourself the time and just cut the bolts off. Get new ones, they are cheap and it will save you the trouble in the future. Just did it myself.
Lifting up a lowered car is a b*tch!</TD></TR></TABLE>
well ill have to cut one of them off. it was much much faster taking the other ones off than cutting them tho. maybe 15 seconds after i broke the 2 loose they came right off.
Old May 17, 2007 | 10:24 AM
93eg2james's Avatar
Default Re: (imadigitalgod)
Haha, I've been in this position as well. If you want to try to salvage those bolts and nuts, you're going to have to use a torch and get them red hot. Once they're red hot, they'll come right off with no problem.
My suggestion is to just not be such a cheap @$$. If you dont have a bench grinder, go get one, and just hack the bolts off and replace them. New nuts and bolts will cost you very little.
Old May 18, 2007 | 09:31 PM
Default Re: (93eg2james)
Car-X hooked me up and torched them then hit them out. i went and got new bolts. i just have to see y the exhaust is hitting my exhaust; atleast thats what it sounds/feels like
Old May 18, 2007 | 10:03 PM
bmoua's Avatar
wow, i have never seen that much rush ever haha...
Old May 18, 2007 | 10:23 PM
SiYouLater's Avatar
Wow thats crazy lol.
Old May 19, 2007 | 01:00 AM
pinoy2o9's Avatar
thats sum nice rust build up. mite as well redue that b-pipe. juss git two new flanges and do it over.
Old May 19, 2007 | 07:05 AM
Default Re: Replacing B-Pipe, Bolts Rusted over question (pinoy2o9)
well its allready on the car and working. i allready replaced the b-pipe so thats new, and im not going to mess with the catalitic converter. it fits together, doenst leak so im not going to mess with it. waste of money right now if i do
Old May 19, 2007 | 07:57 AM
97Ej6mike's Avatar
Leave it be then, you should be fine. That rust is about normal of what you would find on a stock exahust.
kornerk12
Nov 21, 2006 09:59 PM
shorty5198
Honda Civic (2001 - 2005)
Jul 14, 2006 02:23 PM
slammedteg
Mar 15, 2004 04:48 PM
f1uxx
Apr 23, 2003 12:40 PM
steve_s
Apr 17, 2003 09:44 PM
