Stock 92 Civic CX running pig rich
Old May 17, 2007 | 08:44 AM
ThinkRevolution's Avatar
Default Stock 92 Civic CX running pig rich
No mods no nothing.. the white rear bumper is totally black due to how rich it is running. Any ideas?
I searched and it seems everyone that has rich running problems has a swap of some sort. I'm still running my little go kart engine ;P
Old May 17, 2007 | 09:20 AM
instructor74's Avatar
Default Re: Stock 92 Civic CX running pig rich (ThinkRevolution)
Is the check engine light on? Are there any codes? most of the time a running rich on a stock set up is an indication of a bad O2 or unplugged O2. It could be a few other things but that is where I would start
Old May 17, 2007 | 09:57 AM
deadline's Avatar
i dont think it has a cat..
Old May 18, 2007 | 08:31 AM
Default Re: (deadline)
No codes no nothing, it definitly has a cat. Like I said, bone stock. The car also wasnt doing this when I got it, about 6-8 months ago. It has started in the past 2 months.
Old May 18, 2007 | 08:37 AM
Eran's Avatar
HT White Ops
Have you checked for any stored codes that may not be present as a CEL on your dash?
Have you checked your spark plugs to make sure you're getting a good ignition, and thus burning up all the fuel that's peeing into your cylinders?
Old May 18, 2007 | 09:11 AM
truevietluv636's Avatar
Default Re:
same **** happened to my friend.... he had leaking fuel injectors, pull out your spark plugs to see if they're wet.
Happened to my car too... bad o2 sensor.
Old May 18, 2007 | 09:13 AM
Ag-Eng's Avatar
Default Re: Re: (truevietluv636)
I'll go with bad 02 sensor or leaking injector.
Could be both!
scottso990
Apr 15, 2008 04:14 AM
crxricer66
Oct 3, 2007 06:56 PM
sooo_slow
Mar 7, 2005 07:07 AM
B00ST2nR
Oct 19, 2002 02:36 PM
bronzehatch
Jul 22, 2002 02:14 PM
