Honda S2000 Honda S2000
s2k...80k reg oil to amsoil..
Old May 17, 2007 | 07:22 AM
S2kGuy07's Avatar
Default s2k...80k reg oil to amsoil..
wats up my s2k just hit 80k i got it about a month ago previous owner ran reg oil and i wana switch to synthetic amsoil.. friend told me that if i switch it up it will make all my seals leak...wats the deal??
Old May 17, 2007 | 08:51 AM
Flexmyrex's Avatar
Default Re: s2k...80k reg oil to amsoil.. (S2kGuy07)
you shouldnt have any problems switching. it is true though synthetic oil will shrink certain seals that were produced using different materials. The seals on the s will not be affected.
Old May 17, 2007 | 09:47 AM
s2kdre's Avatar
Default Re: s2k...80k reg oil to amsoil.. (Flexmyrex)
any reason why u wanna go to synthetic? regular oil every 3k is good enough.
Old May 17, 2007 | 10:04 AM
b20integrapower's Avatar
Default Re: s2k...80k reg oil to amsoil.. (s2kdre)
if i can remember correctly, synthetic oils have more detergents in them that break down gunk and carbon build ups. Some of this carbon and gunk actually help seal the seals.
So when you add the synthetic, the gunk gets broken down, and potential leaks arise.
Old May 17, 2007 | 10:38 AM
Francesco's Avatar
Default Re: s2k...80k reg oil to amsoil.. (b20integrapower)
if you switch to synthetic, i recamend you do two oil changes.
change it the first time and let the car sit idle for a while, cool down, and then change it again.
Old May 17, 2007 | 12:17 PM
S2kGuy07's Avatar
thanks for the info
Old May 17, 2007 | 04:49 PM
cheese steak Nazi's Avatar
Default Re: s2k...80k reg oil to amsoil.. (Francesco)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Francesco &raquo;</TD></TR><TR><TD CLASS="quote">if you switch to synthetic, i recamend you do two oil changes.
change it the first time and let the car sit idle for a while, cool down, and then change it again.</TD></TR></TABLE>
frank, any reason for the two oil changes??
Old May 17, 2007 | 07:06 PM
rayj8524's Avatar
Using a good true synthetic will help your engine run longer and cooler than dino juice. Why waste time and money changing your oil every 3000 miles not to mention the waste and helping to create a greater dependence on foreign oil. Instead use a good 25,000 mile oil. Seals, from everything I've read, if changing to synthetic causes leaks, that seal(s) was already leaking, it was just some gunk blocking it. On some synthetics, it has been reported it has even help rejuvinate the seal. While this is not guaranteed, it has happened. It is a proven point that a true synthetic oil can raise your gas mileage as much as 3-8%. At $3 a gallon, that's a bonus as well.
Old May 17, 2007 | 11:30 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Default Re: s2k...80k reg oil to amsoil.. (rayj8524)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rayj8524 &raquo;</TD></TR><TR><TD CLASS="quote">Using a good true synthetic will help your engine run longer and cooler than dino juice. Why waste time and money changing your oil every 3000 miles not to mention the waste and helping to create a greater dependence on foreign oil. Instead use a good 25,000 mile oil. Seals, from everything I've read, if changing to synthetic causes leaks, that seal(s) was already leaking, it was just some gunk blocking it. On some synthetics, it has been reported it has even help rejuvinate the seal. While this is not guaranteed, it has happened. It is a proven point that a true synthetic oil can raise your gas mileage as much as 3-8%. At $3 a gallon, that's a bonus as well.
lol. thanks for the laughs.
Old May 18, 2007 | 06:25 AM
Sean Juan's Avatar
Default Re: s2k...80k reg oil to amsoil.. (B serious)
It won't hurt to go either way. I have to believe these oil manufacturing companies such as Castrol, Mobil1, etc. They say it won't hurt.
Old May 18, 2007 | 10:26 AM
evil vapor's Avatar
Default Re: s2k...80k reg oil to amsoil.. (Sean Juan)
no need for two oil changes when switching to syn. Just keep an eye on your oil level and add accordingly. Just stay consistant with the type of oil you use, syn or non-syn.
Bngo731
Feb 1, 2006 04:49 PM
danny98r
Nov 10, 2004 07:08 AM
mattmw88
Apr 29, 2004 01:52 PM
obd1gsr
Dec 25, 2003 09:48 PM
GQ 05YellowEVO8
May 24, 2002 06:25 PM
