Plug Indexing
Old May 17, 2007 | 05:45 AM
lude98SH's Avatar
Default Plug Indexing
I know this will make slightly more power, when i say slightly i mean slightly. This is according to a few books i have read and a few guys that have built honda challenge motors. I have been told it depends on the shape of your combustion chamber and how the plug is positioned in there which way you should face the plug. Does anyone have anymore info on that ?
Old May 17, 2007 | 09:24 AM
1.7na's Avatar
Default Re: Plug Indexing (lude98SH)
I believe the "open" face side of the spark plug should face toward the intake.
I think you are going to need to use washers so you can get them to face the right way and at the same time, be able to torque them to down to specs.
1.7na
Old May 17, 2007 | 10:04 AM
MR.johnson's Avatar
Default Re: Plug Indexing (1.7na)
there has been gains but not much. after my build im going to do it. even if it does not make any more power i have heard it has a better idle and smoother low-end.
Old May 17, 2007 | 05:24 PM
lude98SH's Avatar
Default Re: Plug Indexing (MR.johnson)
yea i know you need to use washers and torque them. But the thing ive heard many differences on is which way to face them. On here most ppl have said intake but i talked to a few guys who teach performance classes and they said the opposite, however idk if hondas differ from most other applications.
And yes i know that the results are minimal but hey all it could do is help and doesnt cost anything
Old May 17, 2007 | 08:07 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
As I understand it it is not necessary and probably wont benifit hondas because of the shape of the C. chambers..
Old May 17, 2007 | 08:21 PM
lude98SH's Avatar
Default Re: Plug Indexing (cb7-R)
hmmmm?
Old May 18, 2007 | 04:59 AM
goldegg's Avatar
I heard the Insight comes with indexed plugs to help fuel mileage.
Old May 19, 2007 | 01:10 PM
lude98SH's Avatar
Default Re: (goldegg)
thats def possible
Old May 19, 2007 | 05:09 PM
night's Avatar
Default Re: (lude98SH)
yes the insight does have factory indexed plugs. 4 different ones. everything is special order on that car.
and it should be to the exhaust side. that is where you want your burn.
but i believe it is more of a matter of flame travel so it goes out more equal from center. the side electrode shrouds the other side of the chamber
Old May 21, 2007 | 07:12 PM
lude98SH's Avatar
Default Re: (night)
the side electrode ??? All i know of is the side and ground electrode... what part of the plug are you talking about or do those plugs have 2 ground electrodes ?
Old May 21, 2007 | 09:24 PM
night's Avatar
center and side or ground. whatever. could only be one option really
but then there is the twin ground/side NGK v's...
EF_RICE
Welding / Fabrication
Oct 20, 2007 07:37 AM
MI4$DC5
Mar 11, 2006 07:56 PM
CRXSi90
18
Aug 16, 2003 11:12 AM
SIK IN DA HED
Nov 25, 2002 02:31 PM
