cut out at 2k
so my car dies out at about 2k but will still rev past that, my main relay clicks when it bogs out. has any one had this problem? I dont know what it could be im flashing iacv but I dont think thats why its messin up, I also am having a cylinder misfire. any ideas?
alright sorry, I was in a bit of a hurry when I wrote that. Here's the situation, I've got a 1988 crx dx with a b16 swap an mpfi my iacv is throwing a ecu code I've already discussed this and figured that I would still be able to run my car just fine. so I bolted up my header cat and a couple feet of pipe so i coulde drive it with out bending any valves. so I take her out and at about 2k revs the engine seems to die then i here the main relay click and it comes back on all with in about a second and i can continue to rev it past 2kthen it happens again around 4k.what could be the problem? also im throwing a code 73 misfire. from what i hear a misfire could be from the distributor an the guy that ran my wiring kept on changing up some plugs on the dizzy. is the misfire and cutting out due to a miswire in the dizzy harness or could it be cause from the iacv? I'm so confused on this one please I need help!
