how to tell when a clutch is out of gas?
Old May 16, 2007 | 06:32 PM
yeegsr's Avatar
Default how to tell when a clutch is out of gas?
I have a stock gsr, before the got it car the owner told me that he has a 6springs clutch and around 75% life left on it. Until now, I have been driving around for 45k on the top of the previous.
Anyway, how can I tell when is a clutch is worning out? by mileage? by the feeling when clutching? etc
Thanks
Old May 16, 2007 | 06:33 PM
Libertariat's Avatar
Ek Forever y0!
Default Re: how to tell when a clutch is out of gas? (yeegsr)
At a standstill try and takeoff from 2nd gear. If it slips and revs instead of stalling out/going into gear then it's starting to slip.
If you can go 0-50 in 2nd gear then you should be good.
Old May 16, 2007 | 06:35 PM
yeegsr's Avatar
Default Re: how to tell when a clutch is out of gas? (ek forever guy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy &raquo;</TD></TR><TR><TD CLASS="quote">If you can go 0-50 in 2nd gear then you should be good.</TD></TR></TABLE>
I can definitely take-off with 2nd...no slipping at all. But generally, what is the life of a clutch in term of mileage?
Old May 16, 2007 | 06:37 PM
ilovemycoupe's Avatar
I'm a Jackass
THIS IS HOW I TRY AND TELL...
i rev to 1k-1.5k rpm and drop it...not hard but enough to still see if theres any throw left in it...
Old May 16, 2007 | 06:40 PM
Ek Forever y0!
Default Re: how to tell when a clutch is out of gas? (ilovemycoupe)
The life of a clutch all depends on the driver. Many people think they drive fine but they still:
1) ride the clutch
2) use the transmission to stop
3) shift too damn much
4) dump at 7000 rpms
5) Don't break in the clutch correctly.
Many factors play into clutch life, there are several people with stock slutches and over 120,000 miles.
All depends on the driver, break-in, and driving style mostly.
Old May 16, 2007 | 06:44 PM
Chim Chim's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yeegsr &raquo;</TD></TR><TR><TD CLASS="quote">
I can definitely take-off with 2nd...no slipping at all. But generally, what is the life of a clutch in term of mileage?</TD></TR></TABLE>
It really depends on you're driving style and habits... A clutch is no different from a brake pad... Think of it like drag launching = hard braking... The more of that you do, the less mileage you'll get out of your brake pads or clutch...
Old May 16, 2007 | 06:46 PM
I'm a Jackass
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy &raquo;</TD></TR><TR><TD CLASS="quote">The life of a clutch all depends on the driver. Many people think they drive fine but they still:
1) ride the clutch
All depends on the driver, break-in, and driving style mostly.</TD></TR></TABLE>
i do this a whole lot especially #1
i also when i downshift from 4th to 3rd
ill throw in neutral lightly rev to 2-3k and thro in 3rd making the syncros have less stress....and also to avoid annoying jerk..
Old May 16, 2007 | 06:53 PM
yeegsr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yeegsr &raquo;</TD></TR><TR><TD CLASS="quote">I can definitely take-off with 2nd...no slipping at all. But <U>generally, what is the life of a clutch in term of mileage</U>?</TD></TR></TABLE>
Very informative replies from you guys...but I think you guys missed reading the question.
by "GENERALLY" I mean for a normal stick driver no hard rev, no redline, no burning clutch...etc you know the general stuffs? What is the average life-mileage-expectency of a clutch?
Old May 16, 2007 | 06:55 PM
I'm a Jackass
average mileage in helms states
"change manual transmission clutch every 30k & automatic every 45k"
direct from helms..
Old May 16, 2007 | 06:58 PM
Ek Forever y0!
Most factory clutches run to 70k. See it a lot.
Brake pads are WAY cheaper than a clutch job, slowing yourself with the clutch/tranny = FTL.
Old May 16, 2007 | 07:00 PM
anavrin351's Avatar
to avoid annoying jerk let the clutch out slower. i play my clutch all the time and the original lasted over 160k. it was still fine when i replaced it, but im an idiot and it turned out to only be my master cylinder.
On a honda a clutch should last 140k as long as you drive right
Old May 17, 2007 | 02:37 AM
Mhollaek9's Avatar
Default Re: how to tell when a clutch is out of gas? (anavrin351)
when your slowing down as in going to a full stop you push the clutch in as your putting it in neutral right?
Old May 17, 2007 | 03:52 AM
bart2546's Avatar
Default Re: how to tell when a clutch is out of gas? (Mhollaek9)
I do at least and I try to use my brakes to slow it down. I believe what most people are referring to when they say using the tranny to slow you down is downshifting while comming to a stop/slowing down as a truck driver has to do (18-wheeler truck drivers that is).
Old May 17, 2007 | 03:59 AM
speedy_beedee's Avatar
With normal driving no abuse my first civics clutch lasted 209,000 miles even then the t/o bearing failed not the clutch.
Old May 17, 2007 | 05:25 AM
instructor74's Avatar
Default Re: how to tell when a clutch is out of gas? (bart2546)
I replace my OEM clutch at 120K do to a broken spring. the clutch had tons of life still left in the friction material. like already said there is almost no way of telling you an average mileage when so many things can shorten the life of the clutch
stilzx61
Honda S2000
Aug 28, 2008 12:05 PM
preluda
Aug 22, 2005 09:50 PM
Komptech
Mar 29, 2005 07:35 PM
civicheaven151
17
Jul 6, 2002 07:25 PM
MrBite
Dec 11, 2001 04:34 AM
