I need help please!! Rough Idle 1000rpm-1600rpm pulsating!!!
Old May 16, 2007 | 04:10 PM
captainscorpo's Avatar
Default I need help please!! Rough Idle 1000rpm-1600rpm pulsating!!!
Ok here's the thing. My fuel pump went bad on my 89 CRX SI a few weeks back. I just replaced it and the car was running fine, for a day. Now when I first start the car in the morning before it's warm it's idling at 2000 rpm, not pulsating.... Once it gets warm though, after like 15 mins. It starts pulsating while stopped from 1000 to 1600 rpms back and forth back and forth. I don't know much about my car I just started working on them and I have no cash to go back to the garage. It's probably something stupid. Any ideas? it would be greatly appreciated.
Old May 16, 2007 | 04:24 PM
2slow4stock's Avatar
Could be a lot of things...
1.Coolant
2.iacv
3.Kink in the coolant lines (intake manifold through throttle body to iacv and back down)
4...?
5.Vacumme (sp?) leak.
Just my .02 cents or what i've done to stop my surging.
Old May 16, 2007 | 04:38 PM
wiZCo's Avatar
Stouts 'n' Scotch
Default Re: (2slow4stock)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2slow4stock &raquo;</TD></TR><TR><TD CLASS="quote">Could be a lot of things...
1.Coolant
2.iacv
4...?
Just my .02 cents or what i've done to stop my surging.</TD></TR></TABLE>
Good stuff
You may also want to check that your throttle plate is closing as it should, that your throttle cable is adjusted properly and your idle speed isn't set too high.
Old May 16, 2007 | 04:42 PM
msinsky14's Avatar
Default Re: (wiZCo)
sounds most likely its a vacuum leak, but then again, i've had a coolant leak before and it caused it to do the same things when there wasnt enought pressure in the lines
Old May 16, 2007 | 04:53 PM
Now how do u check for a vacuum leak?? I checked my hoses I didn't hear any whistling. I jjust replaced my upper radiator hose but I couldn't see anything wrong... And also what's the iacv? Thanks guys.
Old May 16, 2007 | 05:09 PM
iacv is behide the intake manifold right there by the throttle body. Intake Air Control Valve if I am not mistaken.
Old May 17, 2007 | 08:01 PM
blinger's Avatar
IACV or FITV...
Old May 18, 2007 | 03:07 AM
ham's Avatar
ham
Default Re: I need help please!! Rough Idle 1000rpm-1600rpm pulsating!!! (captainscorpo)
Whats up danny, its eric.
When did you replace the upper radiator hose? was it after the fuel pump and right before it started surging?
I'll take a look at it later today or tomorrow, I guarantee you that I will fix it for you.
seeya
Old May 23, 2007 | 03:20 AM
ham's Avatar
ham
for future reference - we bled the air out of the cooling system and reset the ECU and now it runs great!
Old May 23, 2007 | 04:12 AM
bobjohnson's Avatar
Default Re: I need help please!! Rough Idle 1000rpm-1600rpm pulsating!!! (ham)
Thanks!
I always hate it when people get advice and never come back and say whether or not it worked out.
Old May 23, 2007 | 09:17 AM
ham's Avatar
ham
Default Re: I need help please!! Rough Idle 1000rpm-1600rpm pulsating!!! (bobjohnson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bobjohnson &raquo;</TD></TR><TR><TD CLASS="quote">Thanks!
I always hate it when people get advice and never come back and say whether or not it worked out.</TD></TR></TABLE>
thats exactly why i replied. people should do that more often!
Old May 23, 2007 | 09:41 AM
Mr_ET's Avatar
Did you just bleed the system at the rad cap or with the bleed screw next to the upper rad hose?
I have a similar problem after replacing the hose between the back of the intake mani to the TB that had coolant in it.
Old May 23, 2007 | 11:48 AM
dandizel's Avatar
Default Re: I need help please!! Rough Idle 1000rpm-1600rpm pulsating!!! (Mr_ET)
Start the car, turn heater fan on warm/high, top off the radiator with coolant, put the cap on then crack the bleeder screw until coolant comes out. If you still need more coolant repeat steps. Simple stuff
Old May 23, 2007 | 11:55 AM
Mr_ET's Avatar
Default Re: I need help please!! Rough Idle 1000rpm-1600rpm pulsating!!! (dandizel)
will do thx!
itzyaboyzeem03
Jun 29, 2008 12:00 AM
freedomx101
23
Apr 11, 2008 11:16 PM
Rex-Si
Jul 12, 2006 07:36 AM
TurboLex
Feb 25, 2005 10:47 PM
crex23
Dec 18, 2004 11:15 AM
