thread pinch
hey guys gota quick question. im about 2 buy a BLOX shift **** and i c that it says its 10x1.5mm and i think i know wat it is but im trying 2 b sure...thqt is the thread pinch or wat ever it is called rite? (btw if i got it wrong would anybody wanan trouble 2 explain wat it is for me?) and if so does any1 know the thread pinch for an ek shifter? thanks help is appreciated. flamers save it for sumbody else
Yes, 10x1.5mm is the same thread size as the stock unit.
The term you're looking for is "thread pitch", which would be the the distance between two threads (in this case 1.5mm). The 10 indicates the diameter of the threads in mm. So, the threads on the shifter are 10mm in diameter and spaced 1.5mm apart.
