Am I undercammed???
Old May 16, 2007 | 03:45 PM
TNT's Avatar
TNT
Default Am I undercammed???
I have ITR cams with this setup...will they hurt me alot cause of my compression???From my calculation i think i'll be running arund 12.2 CR....
B18A Block(LS Internals)
OBD2 GSR Head with p+p
ITR Valve Train
ITR P-73 00 Pistons(JDM)
Old May 16, 2007 | 03:49 PM
Combustion Contraption's Avatar
With higher than stock compression it stands to reason youll see more power with larger than stock cams. Stock camshafts are designed to provide a balance between good driveability/emissions/power whereas aftermarket camshafts are usually designed for just the max power aspect.
Youd probably get good gains from the standard tubed RAGE header, just dont lowball someone for it.
Old May 16, 2007 | 03:51 PM
TNT's Avatar
TNT
Default Re: (Combustion Contraption)
Thanks for the response...but cmon' man get off that will ya...no one is gonna go out and say they'll pay 400 bucks or whatever(Example) for something they havnt seen...all you had to do was send some pics...no biggie...
Old May 16, 2007 | 03:58 PM
You have your story all upside down
Anyway. Youll make more power with aftermarket camshafts, but youll need an aftermarket valvetrain to go along with it.
lsvtec101
Jan 13, 2009 05:37 PM
JIDUM_Undercover
11
Jun 2, 2005 10:11 PM
smkngsr
Apr 28, 2005 12:28 PM
akasen8
Jun 28, 2004 07:52 PM
redteg1
Mar 6, 2002 09:15 PM
