hey whats a good tire size for 02-04 rsx rims?
Old May 16, 2007 | 03:06 PM
aeenox's Avatar
Default hey whats a good tire size for 02-04 rsx rims?
cause imma get some tires for some rsx rims i have but i dont really know anything about tires
Old May 16, 2007 | 03:23 PM
BarracksSi's Avatar
Here's a start:
http://www.miata.net/garage/tirecalc.html
Input your stock tire size at the top, then fiddle with the other numbers until you find something close.
They originally came with 205/55-16. That's just a hair too much tire for my '02 EP, which came with 195/60-15 tires -- 205/50-16 is the usual "plus one" equivalent. I have 195/55 winter tires on my set now (got 'em with the Type-S hub swap), and I've also used 215/45 Azenis on them.
Whatever profile you end up with, check the manufacturer's own specs for recommended wheel widths for their tire. As a general rule for 6.5" wheels like those, I'd say to not go any wider than 215 or 225, especially if you're going to beat on them.
Old May 17, 2007 | 06:19 AM
05rsxS's Avatar
Default Re: hey whats a good tire size for 02-04 rsx rims? (aeenox)
Falken Azeni's rt615's they are amazing.
Old May 17, 2007 | 01:12 PM
BarracksSi's Avatar
Falken's Azenis sport tires (even the now-discontinued RT-215's that I have) are a BLAST, but for regular driving, I tell people to not bother with them.
I have several reasons (beware, I think I went into lecture mode.. lol) --
They're really not as good as the rain as many conventional tires. If you get in a situation where you must brake very hard or try to maneuver quickly, they're simply not going to work as well as good summer or all-season tires.
They suck when it gets cold (say, 50 degF and below) -- their rubber compound gets too hard to work right. Probably not an issue where you are in Cali, though.
They're soft, and will wear more quickly than most other tires. Sure, they're priced really well compared to other high performance tires, but you're going to eat up more of these than you will almost anything else.
If you have a flat, and you're far from home and need a replacement from whatever tire shop you can find, you won't find anything like this. You'd have to suck it up, get what you can, then drive safely so that you don't discover how much the car's handling balance has been affected.
<u>LASTLY</u>... and this may seem odd for me to say, but follow me...
They are too grippy to be practical tires for street driving.
I say this because their big advantage over most other tires would not -- or should not -- be exploited on public roads. They really do grip harder and corner faster than any all-season tire and probably every summer tire... which means that, to really enjoy them, you would have to be driving at speeds that are simply too dangerous. There are a lot of idiots out there, and they literally won't see you coming.
SO, because you can't fully exploit their abilities, you're left with a fast-wearing, hard-to-find tire that sucks in the rain.
For what they're designed to do -- specifically autocrossing -- they're fantastic. They can account for cutting whole seconds off of my times. Passengers go "holy ****" before the tires reach their limits. BUT... I can't recommend them with a good conscience for use as daily driving tires.
Old May 17, 2007 | 03:23 PM
E-Money's Avatar
Default Re: (BarracksSi)
do they have a hard sidewall?
Old May 17, 2007 | 05:05 PM
BarracksSi's Avatar
Yes, they're purposely made with a stiffer sidewall for better cornering response. They'll do in a pinch as drag tires, but given a choice, you'd want something with a little more compliance for a good launch.
Old May 21, 2007 | 09:56 PM
caeavesRSX-S's Avatar
p225/50R16 is a wider option with the same overall diameter
Milab21
Oct 4, 2010 12:35 PM
enoker001
11
Mar 25, 2008 09:22 AM
timberwulf
May 22, 2007 02:55 AM
tinman24
10
Jul 15, 2006 12:14 AM
nc-rsx-s
Nov 24, 2001 09:41 AM
