got back from dyno, need input for my #'s
Old May 16, 2007 | 02:24 PM
zhan28's Avatar
Default got back from dyno, need input for my #'s
my set up
b20b block:
Eagle H-beam rods
Je 12.5 to 1 cpr pistons
b16a head
Skunk2 Stg 1 cams
Crower titanium retainers
Crower dual valvesprings
Type R intake manifold
dented DC sports Header
Trust (old school Greddy) SP Exhaust with testpipe.
i made 180 whp and 141 torque
my fuel system is stock right now, so my question is with walboro 255 and bigger injectors, would i be able to make 200 whp? or is 180 whp pretty decent numbers for what i have right now? people keep telling me i should be making 210 whp at least, that's really high...
Old May 16, 2007 | 02:31 PM
Jay_Sensing's Avatar
My first guess would be 1, you are low on fuel system for what it "can" make but not yet. 2, your header is killing you. It just won't move enough air. Go for SMSP or RMF or anyone, but if they are too pricey, profab will work wonders over what you have right now. 3, with that much compression, you are slightly under cammed. I would look into a larger set of cams.
With those three things, you would most likely have no problem making 210 + but they are all killing you at the moment, header being the big one (and the exhaust isn't helping if it's under 2.5 inches).
Old May 16, 2007 | 02:56 PM
( o )( o )'s Avatar
Default Re: (Jay_Sensing)
HEADER was my first thought too but I see Jay_Sensing has already beat me too it.
Start with that, then look into fuel/cams.
Old May 16, 2007 | 04:12 PM
zhan28's Avatar
kk will do thank you
Old May 16, 2007 | 05:30 PM
Sam92Teg's Avatar
Default Re: (zhan28)
I have torque envy
Old May 16, 2007 | 06:14 PM
UncleD's Avatar
Default Re: (Sam92Teg)
Bigger cams, better header, make more power.
Old May 16, 2007 | 07:56 PM
JDogg's Avatar
Default Re: (clean rice)
what'd you tune it with??
my buddys car has a similar build but with less compression and ITR cams, it made 210hp... so you are missing a good ammount of power.
Old May 16, 2007 | 08:03 PM
SkankyEJ7's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clean rice &raquo;</TD></TR><TR><TD CLASS="quote">Bigger cams, better header, make more power.</TD></TR></TABLE>
you beat me to it!! skunk2 s1's are realy holding you back along with your header! like you could use a alot bigger cams with 2 litres and 12.5:! compression i say m24x! or s2 p2's
Old May 17, 2007 | 12:21 PM
zhan28's Avatar
it is tuned on BRE obd0, what did your friend with tthe itr cam have for fuel system? stock?
Old May 17, 2007 | 12:29 PM
mar778c's Avatar
Community Builder
Community Influencer
Default Re: (SkankyEJ7)
I don't think it is the cams that are holding him back. The header needs to be addressed 1st. Get a new header (Profab like Jay said) and re-tune.
Old May 17, 2007 | 12:34 PM
QuickDxEk's Avatar
Default Re: (mar778c)
I also dont believe the cams are holding that motor back!! I would address the header/exhaust and a diffrent tune. That is a fair amount of torque but the power isnt there. I have seen b20s push about 190 with stock bottem end tuned on crome!!
Good luck-Keep us updated!!
Old May 17, 2007 | 12:55 PM
mar778c's Avatar
Community Builder
Default Re: (QuickDxEk)
X2 agreed.
jdragon1974
238
Aug 22, 2014 09:42 AM
negusjuda
23
May 26, 2012 02:42 PM
Audia42
Aug 30, 2010 12:20 PM
zhan28
May 20, 2007 12:29 PM
Captain Save-a-Hoe
Apr 4, 2003 01:17 PM
