b20 turbo
Old May 16, 2007 | 01:09 PM
luda-tec's Avatar
Default b20 turbo
i got a garret .60 trim trubo and the down pipe i have makes it so the intake side has to be on the tranny side of the motor. there one problem.. the turbo is to big and hit the bell housing a little bit, right where it reads the engine code on the little metal half moon part that goes from the tranny to the block. has anyone ever heard of shaving that down to make it fit???? and if i do shave it down enough to make it fit is that going to really effect anything?
Old May 16, 2007 | 02:25 PM
EJ1_Ex's Avatar
i've seen people shave the intake side of the turbo just a bit to get it to fit. But what you can also do it flip the turbo the other way around, where the intake turbo faces the powersteering and ac side. Hope this helps a bit
Old May 16, 2007 | 03:38 PM
pat92si's Avatar
Default Re: (EJ1_Ex)
you can trim the block if the clearance is very close to gain that extra little space.
Old May 16, 2007 | 03:41 PM
ferio82's Avatar
Default Re: (pat92si)
this situaion really sucks for you ...
BoostedEgHatchFl
Feb 14, 2010 07:43 AM
lileghatch
Feb 11, 2009 07:38 AM
BOOSTEDgs-R
Feb 17, 2008 04:00 PM
