FUEL PUMP Install.
Old May 16, 2007 | 10:28 AM
jdm4drSi's Avatar
Banned
Default FUEL PUMP Install.
Ok, so my fuel pump is gonna get replaced. Anyone out there with experience replacing this thing, I need your input!
First, how difficult, time estimation and risk associated with this.
POST!
Old May 16, 2007 | 10:32 AM
CRX Toad's Avatar
Default Re: FUEL PUMP Install. (jdm4drSi)
https://honda-tech.com/zerothread?id=1263692 <--- It will be very similar to this.
https://honda-tech.com/zerothread/1508680 <---good source of all things CRX/Civic (EF,ED, ETC)
I also know 65stang90crx has done this he may chime in.
Old May 16, 2007 | 10:34 AM
jdm4drSi's Avatar
Banned
Default Re: FUEL PUMP Install. (CRX Toad)
Thanks Toad. Will look into ASAP.
Old May 16, 2007 | 10:41 AM
65stang90crx's Avatar
I put a walbro 255 in mine by myself. It was pretty hard by myself but with an extra person its fairly simple.
Loosen the straps the tank and let it sag (I replaced the tank at the same time BC mine was rusted inside...got it from Autozone $80), disconnect the wires/fuel lines, and pull the old pump out (easier said than done). It takes a few tries BC you have to twist it a certain way as its coming out if I remember right. A new walbro comes with a kit to fit directly back where the other one went.
It took me by myself 2 hours but I pulled the whole tank out to replace it and took the old pump out on the bench.
Old May 16, 2007 | 11:01 AM
jdm4drSi's Avatar
Banned
Default Re: FUEL PUMP Install. (65stang90crx)
2 hours? Ok... I have someone helping me and am getting all the stuff from the list of parts I need.
I will be replacing my old DX with the EX pump and replacing the FSU as it is starting to give (gave me false readings one day).
Any other things I should watch out for?
Old May 16, 2007 | 11:13 AM
Just make sure you put the boot on the bottom of the pump. Its very important...
Ohh and dont put a used fuel pump in there...its not worth it.
Old May 16, 2007 | 12:02 PM
jdm4drSi's Avatar
Banned
Naw, purchased a brand spankin new OEM EX pump. Brand new FSU too. I dont wanna have to go back in there...
how many washers and **** do I have to worry about?
Old Jun 11, 2007 | 10:54 AM
ClubRX's Avatar
an EX pump? I thought the 92 and up fuel pumps were different
Old Jun 11, 2007 | 03:13 PM
Bserieskllr's Avatar
Default Re: FUEL PUMP Install. (ClubRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ClubRX &raquo;</TD></TR><TR><TD CLASS="quote">an EX pump? I thought the 92 and up fuel pumps were different </TD></TR></TABLE>
they make 4th gen ex's
Old Jun 12, 2007 | 08:21 AM
ClubRX's Avatar
Default Re: FUEL PUMP Install. (Bserieskllr)
ohh is that a 1.6? and would the Si pump be the same? Do DA fuel pumps fit into a CRX Dx?
xTyReaper
May 3, 2010 04:46 PM
trooper0641
Jul 13, 2005 08:21 PM
Kack
Nov 4, 2003 08:01 PM
ebp 99 si
May 2, 2003 02:55 PM
rob1208lv
Feb 11, 2002 06:08 PM
