I NEED A BUNCH OF PARTS FOR MY SWAP..... LOOK AT WHAT I NEED HOPEFULLY SOMEONE HAS THIS STUFF
FOR B SERIES MOTOR
THINGS I NEED ARE:
-EXHAUST MANIFOLD OR SOME KIND OF AFTERMARKET HEADER FOR NOW
-AFTERMARKET CLUTCH WITH HEAVY DUTY PRESSURE PLATE WITH ( I REALLY WANT A 4 PUCK SPRUNG WITH A 1800LB PRESSURE PLATE)
-EAGLE RODS
-HIGH COMPRESSION PISTONS WITH RINGS
-COMPLETE HEAD GASKET SET SEALS AND ALL
-BLOCK GAURD
-HALF SHAFT
I NEED TO FIND THESE PARTS TO COMPLETE MY SWAP SO IF U KNOW ANYONE WITH ANY OF THESE PARTS I WOULD GREATLY APPRECIATE IT
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by x8_andrew_8x »</TD></TR><TR><TD CLASS="quote">
FOR B SERIES MOTOR
THINGS I NEED ARE:
-EAGLE RODS
-BLOCK GAURD
-HALF SHAFT
I NEED TO FIND THESE PARTS TO COMPLETE MY SWAP SO IF U KNOW ANYONE WITH ANY OF THESE PARTS I WOULD GREATLY APPRECIATE IT</TD></TR></TABLE>
I have an extra Caps Lock key you can have for the cost of a stamp.
FOR B SERIES MOTOR
THINGS I NEED ARE:
-EAGLE RODS
-BLOCK GAURD
-HALF SHAFT
From: where i stunt SAND CANYON in Southern California
sleve ur block or post it ! dont get a guard those leave nasty heat marks on ur cylinder walls and dont work well anyways ! they also help u over heat !
http://cgi.ebay.com/ebaymotors...QrdZ1
[url=http://cgi.ebay.com/ebaymotors/Honda-OEM-B-series-Flywheel-and-Clutch-Acura-B16a-b18-b_W0QQitemZ170113219434QQihZ007QQcategoryZ33732QQs sPageNameZWDVWQQrdZ1QQcmdZViewItem[/url]
http://cgi.ebay.com/ebaymotors...wItem
I have a used Toda header missing one of the springs (purely cosmetic) and with a little rust near the primaries for $680 shipped.
i got a set of eagle hbeam rods forsale too. pm for more info/pics will let go for cheap
Try posting in the "For Sale and Want To Buy" post that is revised in the forum monthly:
https://honda-tech.com/zerothread/1974294
per the ITR Forum Guidelines:
5. For Sale/WTB
- Absolutely, positively no bumping of For Sale/WTB links in the ITR forum, by neither the thread creator or anyone else. If a post is getting "Good Luck" or "Thank You" posts more than a day after the original post, the thread shall be locked (if reported).
There is a FS/WTB thread that is stickied. You should post in there. Good luck.
5. For Sale/WTB
x8_andrew_8x
May 18, 2007 11:10 PM
7rrivera7
11
Jul 14, 2006 02:28 PM
CAPFXXXINGLOCKS
