obd2a to obd2b distributor wiring on a SOHC VTEC
Old May 16, 2007 | 08:16 AM
m0nee's Avatar
Default obd2a to obd2b distributor wiring on a SOHC VTEC
Like the title says... I have a 96 civic EX coupe... swapped in a whole 00 D16Y8, the distributor is of the 00 year too. Difference is, the distributor comes with 8 wires total and the harness on my 96 chasis comes with 9 wires.
Another question, I just took my LS swap out to swap into my crx. Would the distributor off that work on my y8? It was running it in my car before I took it out. Thanks!!
Old May 16, 2007 | 02:37 PM
m0nee's Avatar
Default Re: obd2a to obd2b distributor wiring on a SOHC VTEC (m0nee)
up!
Old May 17, 2007 | 10:24 AM
m0nee's Avatar
help?
Old May 17, 2007 | 07:30 PM
virus.EK's Avatar
I used the following link to wire an OBD2A dizzy to OBD2B. Good luck
https://honda-tech.com/zerothread?id=566618
Old May 17, 2007 | 09:35 PM
m0nee's Avatar
Default Re: obd2a to obd2b distributor wiring on a SOHC VTEC (virus.EK)
Holy ****.. you are the muffukken man!
Old Jan 24, 2008 | 02:09 PM
DelSolDon's Avatar
ok, i checked the link above along with a bunch of other links and i still can't find the answer i need.
i have an OBD2B D16Y8 distributor and trying to put it in a '93 Civic Dx with an OBD1 engine harness. i have the distributor wired and working aside from the tach working. where do i get the RPM signal from when there is no BLU wire coming from the distributor?
thanks.
leebarbero
May 19, 2014 08:55 AM
team_hirev
Mar 9, 2009 03:01 PM
wwcrxww
Sep 28, 2008 09:52 AM
Siegfried
Aug 12, 2005 07:21 AM
