DX to ZC wiring conversion question....
Old Jun 1, 2002 | 05:55 AM
USDM 4G VTEC's Avatar
Default DX to ZC wiring conversion question....
i am about to do a DX to ZC wiring convesion for my Mini-Me swap.... i got almost all the wiring done in my mind and i know how to do it...
has anyone do this before
my question is.. do i use a Si or ZC distribuitor.. and if so, theres 2 cables that go to the Cylinder Sensor with a blue/green blue/yellow color cables.... wich sensor its that one?? the DX engine doesnt have it.... its that the extra cables that the Si or ZC distribuitor has?? bc i am thinking this sensor is inside the Distribuitor....
thanxs 4Life
Old Jun 1, 2002 | 06:26 AM
lelopez's Avatar
Default Re: DX to ZC wiring conversion question.... (JDM EF9)
You would use the si dist for the mini me swap.........as far as those two extra wires, yes you have to add them from the ECU to the distributor b/c the dx dist does not have them.
everything is laid down here: http://www.hybrid-k.com/tech/4gtech/dx-zc-wiring.htm
good luck....
L.
Old Jun 1, 2002 | 03:03 PM
Default Re: DX to ZC wiring conversion question.... (lelopez)
yeah i have that even printed here on my hand
i wanted to know since it says Cylinder Position sensor plug!!!! (PLUG!!!)
The si dist has 2 plugs... the round one with 2 cables and the big round one with7 cables on it... just checking if those cables are in the big one, wich are cables with those colors...
i havent got my hands on a dist yet for my swap.... so i cant tell yet wich one./
thanxs for ur help anyways
Tippyman
Feb 8, 2006 03:32 PM
WhatThaFrig
Dec 30, 2002 12:10 PM
the DR.
Jul 1, 2002 06:14 AM
.ShawnD.
May 7, 2002 04:43 AM
