PCV/black breather box question
okay, i've searched for a few hours now and i cannot find the question to my answer.
I have a B18A1 block with a B18B1 head.
I have the black breather box on the back of my block and there are two ports on top.
one port has a hose running from the box to the back of the block
my question is, where do i run a hose to from the 2nd port?
and what is the CORRECT way to hook up the PCV system / black breather box?
The other hose connects to the PCV valve. There is a spot in the intake manifold above the black box where a hose with an opening for the PCV valve goes. The hose from the black box has a PCV valve like plastic valve at the black box and a square end that fits into the intake manifold.
#3 is the valve that fits into the black box, #4 is the hose with the square end, #6 is the PCV valve.
Modified by b19coupe at 10:53 PM 5/15/2007
Your confused because you now have 2 locations for the PCV valve. Your B18A block has a spot for the PCV in the black box on the back of the block and your B18B head has a spot for the PCV valve in the valve cover. I would just pick one location and block off the other. Hope this helps.
K i l l a B e e.
Mar 4, 2009 10:31 AM
