Benefits of port welding in the head
Old May 15, 2007 | 09:02 PM
94vtirozguy's Avatar
Default Benefits of port welding in the head
i want to know the benefits ?
also what are the disadvantages.
I am currently building h22
Old May 15, 2007 | 09:22 PM
Phil M's Avatar
Default Re: Benefits of port welding in the head (94vtirozguy)
Add material to change port angle, fill in dead areas in port, shaping the short turn radius. It's different for each application.
Old May 15, 2007 | 11:18 PM
Combustion Contraption's Avatar
Default Re: Benefits of port welding in the head (Phil M)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Phil M &raquo;</TD></TR><TR><TD CLASS="quote">fill in dead areas in port</TD></TR></TABLE>
If its a dead area, stagnant, why fill it in at all?
Old May 16, 2007 | 05:15 AM
drift4jesus's Avatar
Default Re: Benefits of port welding in the head (Combustion Contraption)
to increase port velocity.
Old May 16, 2007 | 08:34 AM
Phil M's Avatar
Default Re: Benefits of port welding in the head (drift4jesus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drift4jesus &raquo;</TD></TR><TR><TD CLASS="quote">to increase port velocity.</TD></TR></TABLE>
bingo.
Old May 16, 2007 | 08:37 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Phil M &raquo;</TD></TR><TR><TD CLASS="quote">bingo. </TD></TR></TABLE>
But its a dead area. Meaning, if you fill it in, the port doesnt "see" a decrease in CSA, how would velocity increase?
Old May 16, 2007 | 11:40 AM
allnaturalb16's Avatar
because the air is not fondling around in dead space anymore. it is pulled right through without misdirection(more velocity)
Old May 16, 2007 | 12:35 PM
Default Re: Benefits of port welding in the head (allnaturalb16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allnaturalb16 &raquo;</TD></TR><TR><TD CLASS="quote">because the air is not fondling around in dead space anymore. it is pulled right through without misdirection(more velocity)</TD></TR></TABLE>
So are the dead area's really dead/stagnant or are we experiencing tumble/turbulance/reversion here?
Old May 16, 2007 | 03:29 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Combustion Contraption &raquo;</TD></TR><TR><TD CLASS="quote">
So are the dead area's really dead/stagnant or are we experiencing tumble/turbulance/reversion here? </TD></TR></TABLE>
exactly...turbulant air flow because that so called "dead" space is there. Dead referring to "too much" or "wrong" shape resulting in turbulance. which knocks down the velocity.
dead space i guess because it is killing your flow
Old May 16, 2007 | 03:59 PM
Someone is thinking.
Old May 16, 2007 | 06:36 PM
machine4321's Avatar
i love these threads .
keep it goign
Old May 16, 2007 | 08:11 PM
Default Re: (machine4321)
as far as h22 i am not familiar with the cylinder head ports and would not be able to tell if you could benefit from this procedure.
also your build would definitely affect how much velocity is produced
Old May 17, 2007 | 09:46 AM
Professor15's Avatar
Default Re: (allnaturalb16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allnaturalb16 &raquo;</TD></TR><TR><TD CLASS="quote">as far as h22 i am not familiar with the cylinder head ports and would not be able to tell if you could benefit from this procedure.
also your build would definitely affect how much velocity is produced</TD></TR></TABLE>Well from what one porter has told me is that the floors of the h22 head should be raised up a bit in order to increase the velocity.
Old May 17, 2007 | 11:10 AM
Phil M's Avatar
Default Re: (Professor15)
Brad from RLZ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Professor15 &raquo;</TD></TR><TR><TD CLASS="quote">Well from what one porter has told me is that the floors of the h22 head should be raised up a bit in order to increase the velocity.</TD></TR></TABLE>
Old May 17, 2007 | 11:33 AM
Default Re: (Phil M)
Several noted engine developers have stated this. I believe that the long turn side is a little too generous as well. Unless using oversized intake valves.
Old May 17, 2007 | 01:57 PM
Default Re: (drift4jesus)
what is the price comparison between some welding and switching to oversize valves?
do oversize valves even completely solve the problem?
and..is there any advantage to running oversized valves? does it limit your cam selection?
like i said i have never even cracked open an H motor
and with a heavily modified motor (mainly big cams, but everything else also) does the turbulance seize to exist or become greater?
Old May 17, 2007 | 01:59 PM
is the op even using this info?
he hasnt posted since the first post?
94vtirozguy where are you?
Old May 17, 2007 | 02:02 PM
I see no reason for OS valves on an H street motor. Just my .02.
Old May 17, 2007 | 02:37 PM
i have been reading the replies. Yes the h22 is going to be heavily built.
however i am not using oversized valves. The head welding is not a cost issue, just more of the upsaides and downsides of going the way of welding the head.
It will be driven on the street, however it will be going to the track as well. I am not running an off the shelf cam. i will get the specs tonight if that will help
Old May 17, 2007 | 02:52 PM
Dyno Dave's Avatar
Default Re: (94vtirozguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94vtirozguy &raquo;</TD></TR><TR><TD CLASS="quote">i have been reading the replies. Yes the h22 is going to be heavily built.
It will be driven on the street, however it will be going to the track as well. I am not running an off the shelf cam. i will get the specs tonight if that will help</TD></TR></TABLE>
You really need the head sorted out before you go and get cams ground,our H22a CRX that runs 10.83@123mph has NO port welding and use's std size valves and off the shelf cams,just my 2 cents worth.
Regards Dyno Dave
Old May 17, 2007 | 03:16 PM
Default Re: (Dyno Dave)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dyno Dave &raquo;</TD></TR><TR><TD CLASS="quote">
Regards Dyno Dave </TD></TR></TABLE>
does that motor's head have porting or any type of valve grind? what has been done to it?
honda has very good designs and i cant really see a well built head needing welding until or maybe even before it is VERY built up beyond stock casting and parts involved.
and for the OP which porter says that welding should be done? if you can contact him i would like to see what and how the motor was built that he has seen this performed on and maybe a before and after. @10.83 do you really want .1 second for some welding? i cant see the welding helping much unless there really is a poor design in the h22 head
fcukt_teg
Nov 30, 2007 04:03 PM
SiRidiculous
Mar 21, 2007 06:26 PM
Deathwish
Jul 5, 2005 05:10 AM
CivicHatchback14
Nov 15, 2004 11:36 PM
egturbo
Jul 20, 2004 10:57 PM
