Problems with accord 1995 ex 2.2~
Hey guys, i have some questions & just need a bit of help.
1. My radiator water always decreases within usage of vehicle. it makes the engine rise in temperature and i have to keep refilling within time. (not good in hot humid weathers in Malaysia)
Wat could be the problem??
2. The engine seems to behave erratic stuttering when the air-con is turned on. wat could i do to fix on this??
3. From my observation, little white smokes coming from the exhaust pipe.. is it bcoz the need of change on my piston rings??
4. The engine oil seems to decrease very quick (needs to be refilled every once every 2weeks).
Why is this happening??
Any help would be much appreciated.
Thanks!
Modified by turpitude at 6:37 PM 5/15/2007
Thanks!
For numbers 3 and 4, it sounds to me like an oil leak. Check your engine for any oil leaks. Oil leaks happens a lot in Accords years from 1994 - 1997.
nandowln
Apr 30, 2015 08:18 AM
