Need some help on lowering the ride.
Can someone walk me through, step-by-step on how to lower my 7th gen accord EX V6 Automatic about like one inch?
Also would I have any troubles on going over humps or ramps if I lower it one inch?
if you lower your car about an inch then no you wont have to worry about speed bums or anything like that. here is a step by step that i used on my 5th gen. should be the same of similiar for your 7th gen.
http://www.cb7tuner.com/vbb/showthread.php?t=179
if you havent had any springs in mind for your 1in drop you should go with the eibach prokit. they lower 1.2 all around
a question though...wont messing with your suspension void your warranties?
There are a number of options here, do you want springs? Do you want shocks and springs? Do you want a coilover set so that you can manage how much drop you are having?
If you want springs, Tein H Tech's are your best bet. I think they are 1.3" in front and .8" in the back. With that, you won't need to get aftermarket shocks for awhile.
If you want coilovers there are a hundred different options, but most 7th gen owners go with Tein Basic's or another Tein product.
You won't need a camber kit because it isn't that much of a drop. Step by step is a little difficult, and if you don't know how to do this, you will need a mechanic to, because you need a spring compressor, some space, a jack or lift, yadi yadi.
Let me know if this helps or if you need anymore.
Sorry I missed this thread, but I got your PM. It only cost me 100 because I went to a shop because I didn't have a spring compressor, lift, air gun, etc, and I was helping the mechanic out.
It's only a 3 hour job unless the mechanic is completely incompetent, if he's good it can take them 2 hours. That's just for springs it'll take roughly 2 hours. I'm not sure about coilovers, because I haven't done them, but I assume its no different, because you're taking apart the whole assembly just like I had to.
Although if you're doing springs, letting the springs shoot off across the garage is pretty enthralling.
