hids?
Old May 15, 2007 | 04:18 PM
supramr2's Avatar
Default hids?
so i want to put hids on my eg6 and dont want to go with halos or projectors cause i like the oem look...any ideas what kind of headlights i can get that still look stock but i can use for hids....need help thanks guys
Old May 15, 2007 | 04:28 PM
Padawan's Avatar
Darth ModerVader
Default Re: hids? (supramr2)
The best option you'd be able to find would be European E-code headlamps, but even those would be far from ideal.
Old May 15, 2007 | 05:36 PM
JSPECSIR's Avatar
Default Re: hids? (Padawan)
so keep the stock headlights and use casper shields and d2r bulbs. look here http://www.hidexpert.com
Old May 16, 2007 | 01:20 PM
supramr2's Avatar
Default Re: hids? (JSPECSIR)
what are casper shields? have you used this setup?
Old May 16, 2007 | 01:25 PM
bobobob's Avatar
The glare that hids cause is caused by light reflecting of off the botom of the reflector and shines upwards.
The casper shield is a small "shield" that prevents light to reflect form the bottom of the reflector. Its placed under the bulb (between the bulb and the reflector)
do a search on http://www.hidplanet.com/forums or http://www.hidexpert.com
Old May 16, 2007 | 01:27 PM
Libertariat's Avatar
Ek Forever y0!
Default Re: (bobobob)
Before you invest in $150+ plug and play kits that arne't street legal and blind oncoming traffic, I recommend you get some good halogens.
Try the phillips Xtreme, it's not purple, but it actually lights up the road.
Are you doing it for looks, or tired of crappy lighting?
Old May 16, 2007 | 01:28 PM
Tjames8864's Avatar
retro-fit some infinite m35 hids on ur car or something. best way to do it. OEM look with HID lighting
Old May 16, 2007 | 01:37 PM
Padawan's Avatar
Darth ModerVader
Casper shields are a form of "glare shield" that also serves as a mounting adapter to fit a standard D2R HID capsule in an H4 halogen housing. The do reduce glare and allow the capsules to be installed, but the results are still less than ideal.
Old May 16, 2007 | 01:39 PM
bobobob's Avatar
it is, best way is to retrofit or like "ek forever guy" said, invest in good halogens since that's what your lights are made for!
Old May 16, 2007 | 01:54 PM
Thizzed Out's Avatar
Default Re:
just retro fit some OEM projectors into your OEM headlights. thats as stock as you can get. i recommend TSX projectors.
Old May 16, 2007 | 02:02 PM
bobobob's Avatar
or if you want to keep the brights some e46, but those might be to big for the eg headlights.
try contacting a guy on here called "jdmlifestyle" he did a retro on his eg headlights
Old May 16, 2007 | 04:00 PM
JSPECSIR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by supramr2 &raquo;</TD></TR><TR><TD CLASS="quote">what are casper shields? have you used this setup?</TD></TR></TABLE>
ive got the casper shields and acura d2r bulbs in my stock 95 civic housings, and the results are pretty good with minimal to no glare. i also have audi a4 projectors with acura d2r bulbs in black depo headlights in my 94 civic these have the perfect cutoff and have no glare. im extremely happy with both setups, as they both give me much better lighting, and i dont have everybody flashing highbeams at me like i used too with my old plug n play kit. although it did cost alot more for the audi and depo setup. good luck with your setup, if done right you will enjoy it far better than any halogen lamps.
Old May 16, 2007 | 08:47 PM
Striker_1818's Avatar
Default Re: (JSPECSIR)
I'll sell you an fx retrofit...
fits: 92-95 civics...
projectors: fx35: $150
bulbs: 85122+: $40
Ballasts: denso koito D2S/D2R: $160
Headlights: $100
Custom shroud + shroud extension: $40
Bixenon relay harness: $50
Shipping: $30 (tracking # and insured up to 800 bucks)
Labor: $150
Final Price: $ do the math
BTW: I'm not done yet lol im on the aiming stage right now but gots finals soooooo i won't be finishing this until next week
Old May 17, 2007 | 10:10 AM
supramr2's Avatar
thanks for the help guys the reason why i want hids is because im tired of crappy lighting i just might go with retro fitting some in my housings
Old May 17, 2007 | 10:22 AM
mike1114's Avatar
Default Re: (supramr2)
when you retrofit, it is expensive but well worth it.
I ended up spending $550 on my HID setup with TYC projector headlights. They were awesome.
Using the stock headlights just sucks, maybe like said find some depo lights, they are very similar to stock headlights but they have projectors instead, then you can use these to retro HID. But, they are hard to find these days.
Old May 17, 2007 | 03:14 PM
Default Re: (mike1114)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike1114 &raquo;</TD></TR><TR><TD CLASS="quote">when you retrofit, it is expensive but well worth it.
Using the stock headlights just sucks, maybe like said find some depo lights, they are very similar to stock headlights but they have projectors instead, then you can use these to retro HID. But, they are hard to find these days.</TD></TR></TABLE>
retrofitting takes skills...specially on headlights that come stock with reflectors bc u gots alot of trimming to do yet u gotta make it look nice.
If u buy projector headlights and want to swap hid projectors for those halogen projectors already in your projector housing...chances are, sucky projectors such as the s46 and valeo's will fit and u won't benefit much from those.
Old May 21, 2007 | 10:41 PM
Default Re: (Striker_1818)
pimp your headlights!! with oem stuff of course:
Old May 22, 2007 | 01:47 AM
what projectors are those? for a retro
Old May 22, 2007 | 08:33 AM
fx on the left which is what i'll be using...
tsx on the right which i just sold for 110
Old May 23, 2007 | 01:48 AM
damn 110?! very cheap. aye i saw your id on hidplanet. check your PM here.
Old May 23, 2007 | 08:16 AM
Default Re: (Thizzed Out)
just did a research...check your PM
Old May 23, 2007 | 09:57 AM
Daniel-sanB1's Avatar
is the USDM housing any different then the JDM ?
I heard you couldn't retro fit HID in the JDM head lights
Old May 23, 2007 | 10:07 AM
Default Re: (Daniel-sanB1)
these are the tyc...
every housing can be retrofitted...
just need skills for that
kaotikvizion
13
Oct 25, 2009 10:42 AM
2devii
Lighting
10
Aug 3, 2009 06:12 PM
BoboyRS
Lighting
Feb 20, 2009 04:23 AM
honda94accord
Feb 3, 2007 03:22 PM
