D-Series Transmission not catching 3rd Gear AFTER A 4th GEAR RUN!
This is my 3rd Tranny ....I put in a New Exedy Stage 1 Clutchw/ Pressure Plate....on a used Si Tranny from a friend. When i installed my tranny i could hit every gear except 5th gear and sometimes 4th would pop out. People told me it was because my motor mounts might be bad but it worked fine for all my other trannys. PS> I was in the car and drove it with the Tranny before i bought it and before i put it in on the engine i went through all gears and the tranny caught them (spinned the spindle to make sure it was working properly.) Then everything was fine until i was crusing back home on some long *** back roads and i was gunning my car in 4th gear......I topped it out and then threw my car N and coasted. when i went to downshift i saw that 3rd gear was not catching ... ITs there because i put into 3rd and u feel the grinding as if the shifter needs a little more push forward to catch 3rd gear. So 3rd gear was not abused or anything during the cruise so i dont know how a simple TOP end run in 4th gear affected this. I havent looked under the car yet to see if maybe the bitch pin came out. but what do u guuys think could of happend? What do i have to do to catch 3rd gear again since it seems like if the shifter could move one inch forward it would catch it.
So... you topped out in the 4th gear on a d-series? Isn't that like 130-140 or something
. Well, anyways, did you install your clutch properly?
Stay on topic and not what a STOCK D can hit cuz im far from stock...my clutch has been on my car for almost a month now this is the first problem this tranny has given me.
brlabrune
Feb 23, 2009 12:37 PM
Rod.
Nov 7, 2004 01:13 AM
