Rod bolts and head studs
Old May 15, 2007 | 12:40 PM
hybrid2007's Avatar
Default Rod bolts and head studs
I'm rebuilding my bottom end at the moment and was wondering wether its worth doing any work with my rods. The head is stock but will be building it in the future when money allows. My question is how much can stock H22 rods and bolts take? would it be worth getting the rods shot peened and ARP rod bolts installed while i'm in the bottom end?
Also is it neccessary to use ARP head studs for reletively mild build (around 200whp eventually)?
Old May 15, 2007 | 01:37 PM
danny_civic97's Avatar
Im planning on turbocharging my d-series, they highly reccommended me to get some ARP head studs and all that good hardware at least, so its sorta evident you might want to consider that as well.
Old May 18, 2007 | 04:50 PM
stumpyf4's Avatar
Default Re: Rod bolts and head studs (hybrid2007)
OEM head bolts are suppose to be 1 time use only. Replacement ones are $8.34ea ($83.40 for 10) at Baranco Acura Parts. ARP are usually in the $100 range and are reusable. Make sense both financially and performance wise.
Old May 19, 2007 | 12:53 PM
arc_55's Avatar
yeah i would do it while your in there, you don't want any regrets furhter down the road and like stumpyf4 said, you are in the same price range.
swapped95
Sep 21, 2007 07:34 PM
akura404
Mar 3, 2006 02:12 PM
ls95hatch
15
Apr 10, 2004 06:58 PM
ranta18
Sep 1, 2003 01:00 PM
