how to manually turn the cam??
Old May 15, 2007 | 11:19 AM
vitalik's Avatar
Default how to manually turn the cam??
i just build a b16a head and right now it is off the block and i just got a set of aem cam gears thinking i can manually turn the cam but there is no way they r going to turn. i need to turn the cam so i can do the valve clearance on the other two cylinders. so does anyone know how to manually turn the cams????
Old May 15, 2007 | 01:18 PM
gsrious's Avatar
turn them by the bolt that is holding the cam gears on.
Old May 16, 2007 | 04:03 PM
stumpyf4's Avatar
Default Re: how to manually turn the cam?? (vitalik)
Install the gears then turn the big 14mm bolts that hold them onto the cams.
Old May 16, 2007 | 06:30 PM
boosted crx-r's Avatar
Default Re: how to manually turn the cam?? (stumpyf4)
you need to set the valve clearances with the engine assembled if you want everything to be correct, but if you dont care then keep on with what your doing.
hybrid2007
Apr 11, 2008 03:12 PM
rough_draft
Mar 26, 2005 05:32 PM
B18Redline
Nov 30, 2004 11:19 AM
NOSed_b18b
Feb 22, 2002 05:35 AM
