Brake Lines Siezed?
Old May 15, 2007 | 05:50 AM
ImPuLsIvE's Avatar
Default Brake Lines Siezed?
I want to replace the OEM rubber brake lines with SS-Braided lines for my Big Brake Kit. However, the rubber line's screw attachment seems to be seized onto the metal lines coming from the Master Cylinder. Are the metal lines able to be cut and re-threaded? Or is it simpler to remove them and replace them entirely? All 4 (front and back) lines seem to be seized as well!
Old May 15, 2007 | 06:05 AM
nonvteclude's Avatar
Default Re: Brake Lines Siezed? (ImPuLsIvE)
what are you trying to take them off with? have you tried flare wrenches?
Old May 15, 2007 | 06:10 AM
ImPuLsIvE's Avatar
Default Re: Brake Lines Siezed? (nonvteclude)
just a normal #8-#10 key
Old May 15, 2007 | 07:18 AM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ImPuLsIvE &raquo;</TD></TR><TR><TD CLASS="quote">just a normal #8-#10 key </TD></TR></TABLE>
Seriuously don't do that. Take it from someone who has removed ABS and ran all new custom lines to each wheel, you do not want to use a normal wrench. Get a set of flare nut wrenches and soak the fitting in WD-40 or PB Blaster or whatever you like. Stripping a brake fitting is very not fun.
Old May 15, 2007 | 07:35 AM
Rosko's Avatar
Default Re: Brake Lines Siezed? (Hawkze_2.3)
^^good call... your pretty much f'ed in the a without flare nut wrenches when doing brake stuff.
Old May 15, 2007 | 11:48 AM
InvaderTrax's Avatar
My problem was my OE lines were metric and my SS were standard, but the threads were the same. I used a regular open ended wrench for 3 of the lines, and the 4th one stripped out so I ended up working some vice grips on
Old May 15, 2007 | 02:57 PM
axlline's Avatar
Default Re: (InvaderTrax)
Invader who made your line? Never heard of standard nut with metric threads
Old May 15, 2007 | 03:59 PM
Rosko's Avatar
Default Re: (axlline)
I just bought 3/16 line for most of mine and reused all the metric flare nut ends.
Old May 24, 2007 | 07:37 AM
ImPuLsIvE's Avatar
the bastards are still seized. Even after using a 10mm flared wrench. ARG!
Old May 24, 2007 | 07:44 AM
MugenHonda's Avatar
From: With my POS D15B2, Whereever whenever, United States
Default Re: (ImPuLsIvE)
well no offense, you're fucked and you have to run your own lines
Old May 24, 2007 | 11:16 AM
integra15's Avatar
Default Re: (MugenHonda)
Well if you end up rounding them off you can just use vise grips as a last resort.
brokebuilder
Jul 6, 2017 08:52 AM
Nickb257
May 4, 2010 01:44 AM
Paprika
Nov 28, 2004 01:14 PM
eh2 nihonjin
10
Sep 29, 2003 04:33 AM
