i have a question on brakes.....
Old May 15, 2007 | 03:00 AM
doogi0122's Avatar
Default i have a question on brakes.....
i have a question in reguards to my brakes.....i am putting 17s on my 94 si
should i get bigger brakes? or just go with upgrades, better calipers and the new ceramic pads? any input is greatly appriciated
Old May 15, 2007 | 09:48 AM
Speedra500's Avatar
Default Re: i have a question on brakes..... (doogi0122)
vtec calipers & rotors if you want better braking
Old May 15, 2007 | 09:52 AM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doogi0122 &raquo;</TD></TR><TR><TD CLASS="quote">i have a question in reguards to my brakes.....i am putting 17s on my 94 si
should i get bigger brakes? or just go with upgrades, better calipers and the new ceramic pads? any input is greatly appriciated</TD></TR></TABLE>
Are you wanting to make the car slower? Big brakes plug big wheels = big drag on the engine from the weight.
If you do anything, get some VTEC calipers and good pads (Hawk HPS are good) and if you need it, some new blank rotors.
Old May 15, 2007 | 06:19 PM
doogi0122's Avatar
Default Re: i have a question on brakes..... (Hawkze_2.3)
what do u mean blank rotors or do you mean no drilled slotted?
Old May 15, 2007 | 06:24 PM
Chris F's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doogi0122 &raquo;</TD></TR><TR><TD CLASS="quote">what do u mean blank rotors or do you mean no drilled slotted?
Right, no drilled or slotted rotors in front. They only weaken the rotor.
I use drilled rotors in the rear of my racecar because they last forever and are lighter.
Old May 15, 2007 | 06:25 PM
m00nr0ck Si's Avatar
Yes , blanks are just solid...no need for holes in your rotors that will crack eventually.
Brembo blanks from autozone+ Hawk pads = brake seX
Old May 15, 2007 | 06:35 PM
doogi0122's Avatar
Default Re: i have a question on brakes..... (dorkoftheyear)
thanx alot guys big help all repalys are and will be as always greatly appricaiated
Old May 16, 2007 | 06:34 AM
NirVTEC's Avatar
Blanks FTW!!
Although if youre not racing HONDA OEM pads rule!
Old May 16, 2007 | 06:45 AM
93sivtec's Avatar
Powerslots are nice rotors for hondas,and they dont crack.
Old May 16, 2007 | 07:08 AM
NirVTEC's Avatar
Default Re: (93sivtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93sivtec &raquo;</TD></TR><TR><TD CLASS="quote">Powerslots are nice rotors for hondas,and they dont crack.</TD></TR></TABLE>
And theyre also a waste of money....I pay $25/each for rotors I turn 20-30min sessions on with full blown track pads and they are still perfect....
Power slot/cross drilled......just for show.
Old May 16, 2007 | 07:21 AM
93sivtec's Avatar
Weird I got my power slots for 50 a set,so no waste of money for me then considering they were the same as oem,and look nicer,lol.
Honestly there alot of debate on this topic,but my argument remains if the slotted rotors are useless why do they put them on top end cars straight from the factory? Some say just for sales,but I bet the engineers have a reason.Im sure they have a better grasp on braking than most.For daily driving I belive oem brakes are more than adequate,but through my own personal experience,I need more for my driving style.....Ive upgraded my pads/fluid/lines/and rotors and my car stops like a champ w minmal fading,no matter what Im doing,track days or autosrossin,or just carving up a mountain road,I have the braking response I need when I need it and its consistent.My oem set up was no where near my set up today.
Just my .02.
Old May 16, 2007 | 06:31 PM
SLIPSTICK TIPPIN's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93sivtec &raquo;</TD></TR><TR><TD CLASS="quote">Weird I got my power slots for 50 a set,so no waste of money for me then considering they were the same as oem,and look nicer,lol.
Just my .02. </TD></TR></TABLE>
second that mine brakes like a champ and i did ss lines, powerslots, hawk pads, motul fluid flushed
Old May 16, 2007 | 06:36 PM
ludeing1's Avatar
what all is involved in swapping a si's for some vtec fronts? the whole spindle ? or just the calipers and rotors??
Old May 16, 2007 | 06:58 PM
petern101's Avatar
Cross-Drilled /Slotted Rotors
The second thing you can do to improve your brake performance is often to go to a larger rotor. We all know that this gives the rotor further ability to dissipate heat away from the pads through itself and through the air (conductive and convective heat transfer). So obviously a larger pad, a larger rotor, or both result in better brake performance by avoiding brake fade.
But what about cross drilled or slotted rotors? Well the common belief in the main stream is that somehow slotted or cross-drilled rotors allow for better performance by handling heat. This is 100 percent false. The individuals involved in such fallacies mention that air through the holes or slots work to cool the rotor (convective heat transfer into the air from the rotor). The issue is that from physics we know that metal transfers heat better then air by a significant amount. As such the larger mass of the rotor becomes more important then the larger surface area of the rotor in any situation other then the optimal. Cross drilling and slotting rotors are not optimal manners of creating metal to air transfer through larger surface areas. There is not much airflow through the holes or slots. Furthermore for cross drilling the holes will fill with brake dust in effect lowering the cooling ability of the rotors vanes they pass through.
just science..........
Old May 16, 2007 | 07:19 PM
doogi0122's Avatar
Default Re: (petern101)
so it appears we have a few different thorys , views or however we want to say it
i am more confuzed than anything
i know what i like
i know what i think looks kewl
i thought i was asking a simple question
i wasnt trying to start the debate of the century
i thought the drilled/slotted rotors looked kewl
wasnt sure how they would hold up
unfourtunatly i still dont
i have read different opinions
i have read websites selling them
i guess i will have to go out and look for what i like and if its not good the nill know better nexttime
and my deepest apologies to anyone i have offended with my mis spelling of VTEC
the bad part is i was just looking at a element sc with the I-VTEC engine
of wich i fell hard
i want one (but my prelude goes no where thats my toy) the element is for work
anyhow guys thanx for the input now i have decisions to make.........but hey i still need tires for my new wheels but i digress thats another post for another day
l8tr
Old May 16, 2007 | 08:10 PM
93sivtec's Avatar
For daily driving any rotors will hold up fine,from oem to ebay to brembo,they will all be fine.Oem will warp eventually as will the ebays,I have no personal exp w brembos or rotoara's or any other high dollar rotor,so cant speak for them.Any will be fine.
Old May 17, 2007 | 09:39 AM
petern101's Avatar
Default Re: (doogi0122)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doogi0122 &raquo;</TD></TR><TR><TD CLASS="quote">so it appears we have a few different thorys , views or however we want to say it
i know what i like
of wich i fell hard
l8tr</TD></TR></TABLE>
i would also apologize for your horrible typing/english/grammer skills. its much easier to read coherent senteneces than thoughts.
93civicjaydm
Honda Civic (2006 - 2015)
17
Apr 23, 2008 09:19 AM
sin2o3
Sep 5, 2007 12:20 PM
datssoled
17
Jan 6, 2007 04:50 PM
DelsolioGSR1996
Sep 4, 2006 05:14 PM
eluder33
Nov 15, 2004 09:12 PM
