obx lsd problem
Old May 15, 2007 | 02:29 AM
civicsi401's Avatar
Default obx lsd problem
i have a b16a2 tranny just had the lsd put in and now when the cars in gear with my foot on the clutch the car wont roll . it will drive but not sure what this problem is any help would be great and its a obx lsd. has centerforce dfx clutch and pp and centerforce flywheel
Modified by civicsi401 at 3:47 AM 5/15/2007
Old May 15, 2007 | 06:09 AM
mikeycivic's Avatar
Default Re: obx lsd problem (civicsi401)
um usually when the clutch is pushed in the car wont go anywhere unless on a hill. What do you mean wont roll?
Old May 15, 2007 | 07:48 AM
civicsi401's Avatar
Default Re: obx lsd problem (mikeycivic)
i mean in my garage with the car off i had a friend put it in gear and step on the clutch while i pushed kinda hard on the car and it wouldnt move but when the car is driving it seems fine i mean its a very aggresive clutch but i dont think this is suppose to do this
Old May 15, 2007 | 09:43 AM
orb's Avatar
orb
I'm not too sure the "push" test is a very accurate way to go about this. I would suggest finding a very steep hill and letting the weight of the car do the work for you. I just can't imagine the OBX engineers factoring in someone pushing their car as one the performance goals in their design phase. Not to be an ***, but what I'm saying is whether or not you can push your car around is a moot point, really.
Old May 15, 2007 | 10:07 AM
BlackoutVTi's Avatar
Default Re: (orb)
There will be some qwerks when you go to OBX for supplies such as an LSD, so bear that in mind, but I don't think not being able to push it with one person while its in gear with the clutch depressed should be a problem to lose sleep over. I'd agree with the suggestion of the downhill test.
Old May 15, 2007 | 10:48 AM
civicsi401's Avatar
Default Re: (BlackoutVTi)
only reason i ask is i have 4 civics 93cx 95 ex 99si '''''2000 si has lsd'''''none have the lsd but i can push like i stated very easy . i just didnt wanna burn the clutch or flywheel out over $1000 for the setup to much to waste u know rather get some opions then get none and find out it was a bad thing just being carefull is all im doing
Old May 15, 2007 | 10:49 AM
Default Re: (civicsi401)
If you're really concerned about it, double check the clutch/flywheel setup
Stopsign32v
Feb 1, 2011 08:14 PM
Chiller
Feb 20, 2006 02:05 AM
BahamaEKcrvtec
Dec 16, 2004 01:38 PM
xplhavoc
Feb 23, 2004 07:03 PM
