What Tranny Parts Am I missing??
I hate to sound like a rookie, but I need help finding what parts I need to get my swap running. I just picked up a bare hydro LS tranny to finish up my swap and I don't know exactly what parts I need to get the tranny working. I know I need a slave cylinder, but thats all i can think of.
Can anyone provide me with a list of things that I need to pick up for just the tranny to get it all hooked up and working.
well it helps if you tell us what you have
youll need
clutch, flywheel, pressure plate, trans, slave clylinder, fork, throwout bearing, the rubber line from the slave cylinder to the hardline....
youll need
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bleedblue94 »</TD></TR><TR><TD CLASS="quote">well it helps if you tell us what you have
youll need
clutch, flywheel, pressure plate, trans, slave clylinder, fork, throwout bearing, the rubber line from the slave cylinder to the hardline....</TD></TR></TABLE>
i have pretty much everything, like clutch, flywheel, and all that good stuff. I just need help piecing together all the hydro pieces because I'm missing all of that.
youll need
youll need
he pretty much told you all the hydro parts you need.
put on the flywheel > clutch > pressure plate > throwout bearing and fork on transmission > put on transmission > put on slave cylinder > attach to rubber line which should be attached to hard line
the bold is the hydraulic pieces...hope this helps
youll need
