how to clean n polish a used crankshaft
Old May 14, 2007 | 10:44 PM
TypeRbuild718's Avatar
Default how can i clean n polish a used crankshaft?????
well. i just got a crankshaft..looks fairly well....but in sure it could look better....can i get some pointer on how to make it look new again? or closest to it ..can i use break cleaner? wd-40?..... might be a stupid question. but i prefer ask a dumb question then make a dumb mistake......
Modified by KidBluff718 at 12:11 AM 5/15/2007
Old May 15, 2007 | 03:27 AM
Finland's Avatar
If the journals are smooth and shiny (like they should be) just use a lint-free rag and wipe them off. You can use brake cleaner, which will evaporate without leaving behind any residue. Then use the wd40, or clean engine oil to coat the journals to keep them from rusting before assembly.
As far as polishing...you aren't going to be able to properly do that by hand. It's done by a machine at the machine shop. (it's called a micro polish).
Old May 15, 2007 | 04:12 AM
Dave_B's Avatar
Your polish, and what a machine shop considers polish are 2 different things. Since I see your in Kissimmee, I'd say contact a local machine shop (like AutoMachine or a few others) and they can take care of it.
Old May 15, 2007 | 05:43 AM
thanx guys.....will do
Old May 15, 2007 | 05:05 PM
itr1244's Avatar
Default Re: (KidBluff718)
there was a thread somewhere in the performance forum
i think u can get it cleaned/balanced by benson
Old May 15, 2007 | 07:29 PM
Runnerdown's Avatar
Default Re: (itr1244)
the only way to properly clean a honda crank is to have the oil plugs ***** removed. You will know what i'm talking about when you see it.....
EG-SIXV-TEC
Jan 19, 2010 01:10 PM
Peter Brady onlyonweekndz
Nov 26, 2007 12:55 AM
lv6l
11
Oct 18, 2005 07:08 PM
magic hat #9
Oct 28, 2003 03:31 PM
keithv
Jun 14, 2001 06:44 PM
