ac problems? perhaps
Old May 14, 2007 | 10:00 PM
EP_three's Avatar
Default ac problems? perhaps
alright basically my ac blows full power as soon as i turn on the car i dont even need to start it but it blows just normal air and doesnt blow anything cold it does blow hot air when i switch it over....any ideas? thanks and its and ep btw.
Old May 15, 2007 | 03:10 AM
pnjbiboye's Avatar
Default Re: ac problems? perhaps (EP_three)
since your car in not started the compresser can't work. So when you have your key in the on postion its just blowing air... im not an hvac person so if any one can explain it better or correct me.
Old May 15, 2007 | 04:42 AM
risktypeS's Avatar
does it blow cold air when your car is in motion? If you start your car and sit at idle your not going to get cold air. the compressor may kick in when you start your car but the way it works is when your car is in motion that's when it circulates the freon more efficently. At idle speed that's not enough energy to circulate the freon. IF you give it gas at idle(not recommended if you just started your car) you'll notice it will start blowing cold air. IT works off your belt and at idle speed is not enough energy.
Old May 15, 2007 | 07:08 AM
EP_three's Avatar
yea i know all of that.....but it continues to blow even when i switch the level off...it continues to blow at full power and i dont know whats the deal im not worried about cold air i know you gotta be in motion and all. i was just saying that the ac blows even when i dont start the car and the power level is off.
Old May 15, 2007 | 08:39 AM
risktypeS's Avatar
Default Re: (EP_three)
aaah ok i understand your question now...may want to check your fan relay.
Old May 15, 2007 | 01:08 PM
EP_three's Avatar
Default Re: (risktypeS)
and what am i checkin for? i dont think the fan is spinning not 100% sure though
Murf72
Honda CR-V & Element
Jun 17, 2014 06:45 AM
hondaracin24
Feb 27, 2006 06:10 PM
darkfx
May 18, 2005 02:14 PM
jkoshy18
May 27, 2004 03:31 AM
abeaujuin
May 9, 2004 08:18 PM
