which is the best brake master cylinder?
Old May 31, 2002 | 09:12 PM
88CRXHybrid's Avatar
Default which is the best brake master cylinder?
Well it is going out and for sure need a new one. The question is which one is the best to get and what would I need to swap it out. I can not switch to rear discs because of my suspention setup. I also already have the fastbrakes/wilwood 11" setup with slotted/vented rotors and porterfield R4-S pads already on there.
Old May 31, 2002 | 09:32 PM
Steve91's Avatar
Default Re: which is the best brake master cylinder? (88CRXHybrid)
I've been told that the 89 Accord LXI is a direct drop in and is 15/16" where the stock CRX is 7/8"
Old May 31, 2002 | 09:33 PM
wronghand's Avatar
Default Re: which is the best brake master cylinder? (Steve91)
I have heard that as well. The 90-91 EX is a 15/16 as well and I know it is a direct bolt in. That is what I have in my car.
Old May 31, 2002 | 09:38 PM
Default Re: which is the best brake master cylinder? (wronghand)
so all I would need is the master cylinder. what about the preportioning valves. would I need to change them also?
Old May 31, 2002 | 09:41 PM
I think I remember reading something somewhere about swaping over a 91 model prelude master cylinder. It that a 1"? how hard would it be to do? Could you noticably tell the difference before and after the swap?
Old May 31, 2002 | 09:47 PM
Stinkalope's Avatar
New User
My m/c on my 90 Crx Dx is a 13/16, I checked. The car came with Sir rear disk already. I was told I need to swap my proportion valve to a all disk car. The all wheel disk one puts it a little more to the rear to balance out. I don't feel I was much help, sorry....
Somebody find out about the 1" m/c, I'm game!!
Old May 31, 2002 | 10:19 PM
Stinkalope's Avatar
New User
Found some more info:
It fit but was not new: http://crx.honda-perf.org/articles/b...bigbrakes.html
It works but what size?: http://www.overboost.com/story.asp?id=249
Also good link: http://tjshondas.20m.com/xlfronts.htm
Old Jun 1, 2002 | 11:56 AM
Giuseppe's Avatar
Default Re: which is the best brake master cylinder? (Stinkalope)
the 91 prelude mc is 15/16 its a bolt on affair.
ive tried the 4040 prop valve and as far as braking
is concerned i found no difference
with it in or out, compared to the stock 4G prop valve.
hth
Old Jun 2, 2002 | 08:07 AM
crxjdmsir's Avatar
Default Re: which is the best brake master cylinder? (Giuseppe)
What about an 88 LX Accord? I'm about to junk one so that would save me some $$$.
5.0 Killa
Suspension & Brakes
Oct 29, 2009 10:40 AM
em1pusha99
11
Jul 21, 2009 06:27 PM
lukew
Aug 29, 2005 09:50 PM
tRex99
25
Feb 27, 2005 04:24 PM
JobberRadio
15
Nov 30, 2004 07:13 AM
