car wont start after mpfi swap!
Old May 14, 2007 | 09:41 PM
jdm206's Avatar
Default car wont start after mpfi swap!
ok my car is acting funny. its not starting anymore after my mfpi swap. it started before but now its not. what should i check first. also im throwing 2 code. a code 4 and 16. but dont worry i know what those codes are.
Old May 14, 2007 | 10:12 PM
90sedan's Avatar
Default Re: car wont start after mpfi swap! (jdm206)
Well if you know what those codes are...start by clearing them. By fixing those, your car should start/run correctly.
What information did you want?
Old May 14, 2007 | 11:44 PM
jdm206's Avatar
Default Re: car wont start after mpfi swap! (90sedan)
the only code im having real trouble with is 16. i really dont know what to do.
Old May 15, 2007 | 12:00 AM
90sedan's Avatar
More than likely it's your wiring that is the problem. Double and triple check everything.
luckystryx
Aug 29, 2018 06:15 PM
{EF9} GrEaZe m0nKeY
Aug 12, 2009 09:26 PM
1xfastxhatch
Dec 10, 2008 11:55 AM
Lo-Buck EF
16
Aug 22, 2003 05:39 AM
