BC spec2 stage2 cams (in304, out304) questionare
guys...
about BC cams...
1. I found that duration at exhaust is larger than intake... about 10deg diference... is it true or manufacturer fail...?
2. found also 2ndary lobe duration same degree with vtec lobe but for sure has difference lifting... is the basic cams dialing will be like this because i've experienced dialing b16a cams n found that 2ndary lobe has similar duration with vtec lobe... did miss something...?
3. sorry to ask this noob queston... what is the purpose of primary n 2ndary lobe in term of vtec operation...?
about BC cams...
