Will a skunk 2 intake manifold fit in my EF
Old May 14, 2007 | 06:51 PM
CRXHFB16's Avatar
Default Will a skunk 2 intake manifold fit in my EF
I am getting a Skunk 2 intake manifold for my 91 B16a CRX i have heard it has clearance problems is that true?
Modified by CRXHFB16 at 1:17 AM 5/15/2007
Old May 14, 2007 | 07:23 PM
Mr. Giggles's Avatar
Default Re: Will a skunk 2 intake manifold fit in my EF (CRXHFB16)
no.
Old May 14, 2007 | 08:47 PM
civicflow's Avatar
it will rub on the firewall. at least with a d16z6 in my ef it did. you just have to dent in the firewall a little.
Old May 14, 2007 | 10:44 PM
Bob_760's Avatar
Default Re: Will a skunk 2 intake manifold fit in my EF (civicflow)
im pretty sure thats a d-series only issue.
Old May 14, 2007 | 10:51 PM
Deetz's Avatar
Crazy Honda Guy
Just go with an oem P30, it'll make more power than the skunk II anyway.
Old May 14, 2007 | 11:03 PM
hybridmiklo's Avatar
Default Re: (Deetz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Deetz &raquo;</TD></TR><TR><TD CLASS="quote">Just go with an oem P30, it'll make more power than the skunk II anyway.</TD></TR></TABLE> I don't know bout that . BUt I do know it will not have a problem whatsoever fitting in your rex. I have ran one myself as well as a friend of mine.
Old May 14, 2007 | 11:11 PM
Deetz's Avatar
Crazy Honda Guy
Default Re: (hybridmiklo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridmiklo &raquo;</TD></TR><TR><TD CLASS="quote"> I don't know bout that . BUt I do know it will not have a problem whatsoever fitting in your rex. I have ran one myself as well as a friend of mine.</TD></TR></TABLE>
I have yet to see a dyno prove any gain over the P30 intake, and thats how i know what makes power. If you'd search, you'll see this has been covered before.
CRX 2.0V-T's Avatar
wtf? s2 manifold is recommended to swap B series in EF. check out Ryan page, he used S2 mani. Damn people need to stop give out wrong info.
Here is Ryan's page
http://www.norcalcrx.org/dropp...p.htm
Old May 15, 2007 | 02:35 AM
blazed_racer's Avatar
what is a P30 intake?1
Old May 15, 2007 | 03:40 AM
fin781's Avatar
Default Re: (blazed_racer)
my friend has a 88 rex, and he said he had clearance problems. people do people dont. just do it and find out.
Old May 15, 2007 | 05:41 AM
ludesrv's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blazed_racer &raquo;</TD></TR><TR><TD CLASS="quote">what is a P30 intake?1</TD></TR></TABLE>
It's a second gen B16 IM. Nothing fancy. Why replace stock with...expensive stock parts?
Old May 15, 2007 | 05:44 AM
Skipper75's Avatar
i have a skunk2 im and it fits fine. i had to modify a couple little things,but maybe i have an older version
Old May 15, 2007 | 06:15 AM
iheartmyh0nda's Avatar
Default Re: Will a skunk 2 intake manifold fit in my EF (Skipper75)
yeah man, it should fine man, it just replaces the existing intake mani in size, but does better in power etc.
Old May 15, 2007 | 06:31 AM
Furyof4's Avatar
Default Re: Will a skunk 2 intake manifold fit in my EF (PleaseKeepOffDunes)
A skunk2/itr type will get killed by a p30 manifold until 7k. There are plenty of dynos floating around to prove it.
To answer the op's question though, it should fit fine.
Old May 15, 2007 | 07:00 AM
Wes V's Avatar
Default Re: Will a skunk 2 intake manifold fit in my EF (Furyof4)
I've got a Skunk 2 manifold on my B18c in 89 hatchback. No problem!!
You however have to keep in mind that the engine placement also enters into it.
Wes
Old May 15, 2007 | 03:19 PM
Default Re: (ludesrv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludesrv &raquo;</TD></TR><TR><TD CLASS="quote">
It's a second gen B16 IM. Nothing fancy. Why replace stock with...expensive stock parts?</TD></TR></TABLE>
Ahh, i thought so.
is it a straight forward swap? is there any wiring issues, going from Gen1 to Gen 2?
Old May 15, 2007 | 05:20 PM
Deetz's Avatar
Crazy Honda Guy
No issues, i've done it.
Old May 15, 2007 | 08:08 PM
what about all the IAVC valves etc from the GEN1, which sits on the firewall on EF9's?
do you swap them out for the GEN2 ones that mount onto the GEN2 mani?
Old May 15, 2007 | 08:09 PM
sorry for the hi-jack'd thread!
whiteguyndahood
Nov 9, 2007 07:45 PM
Vovchandr
Feb 25, 2007 09:08 AM
VHOA
19
Apr 30, 2006 11:07 PM
jdmludeaz
Apr 25, 2006 05:05 PM
AgentJam
Nov 23, 2004 12:50 PM
