Idle is way off
Old May 14, 2007 | 06:30 PM
crxpwr1's Avatar
Default Idle is way off
I jost got my swap done and every thing is fine...just got done doing the valves and it was iding fine before I did the valves and now when I let off the gas it shuts off. I was wondering if you turn the idle control screw on the throttle body which way does what.....like if you turn it right if that makes it idle higher or if you turn it left it turn the idle down?
Old May 14, 2007 | 07:00 PM
crxpwr1's Avatar
Default Re: Idle is way off (crxpwr1)
bump
Old May 15, 2007 | 10:03 AM
blinger's Avatar
tune
Old May 15, 2007 | 10:09 AM
91ed9's Avatar
Default Re: Idle is way off (blinger)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blinger &raquo;</TD></TR><TR><TD CLASS="quote">tune</TD></TR></TABLE>
also left is higher and right is lower on the idle screw on the TB
99d-series
May 18, 2009 04:51 PM
invisible
16
Mar 26, 2007 01:51 PM
rockenuptown
Jan 12, 2007 11:34 AM
redED9Si
Aug 21, 2005 06:58 PM
fe519
Nov 21, 2002 05:58 PM
