Bearings 4 B20
Old May 14, 2007 | 06:18 PM
UMYB20's Avatar
Default Bearings 4 B20
Can anyone help me wanna know if b16a2 bottom end main bearing are the same as b20. An if anyone got jun stage 3 settings thanks
Old May 14, 2007 | 09:17 PM
89EF_Turbo's Avatar
Default Re: Bearings 4 B20 (UMYB20)
All b-series use the same bearing diameters to a close extent. Only thing is these bearings are color coded for different thickness's, so to order a set of bearings for a b16 will probably not be the set of bearings that will clearance out properly in your b20. The underside of the block has a 5 letter code stamped on it for the 5 main bearings, simply match these letters up to the number stamped on the crank. The honda service manual has the corresponding chart to tell you what color bearings to use.
supra-n-civic
Nov 30, 2009 08:03 AM
V3ND3TTA
12
Aug 25, 2008 05:47 PM
calishowa
Jul 10, 2008 11:45 AM
lsvtecvx
Apr 2, 2003 07:13 PM
