already searched and found nothing. difference in 1.6 and 1.8 liter
Old May 14, 2007 | 06:08 PM
rdeezy78's Avatar
Default already searched and found nothing. difference in 1.6 and 1.8 liter
Kind of a noob ? but here goes. I know b16 are 81mm and b18 are 81.50 right? Now does a .5 mm make up .2liters on the bore size, or is it in the stroke of the crank? Reason I'm asking is because I'm boring and sleeving my gsr block to 83mm. Does it still qualify as a 1.8 liter or so on with the larger bore? No flames please, just trying to get some general knowledge. Thanks
Old May 14, 2007 | 06:10 PM
1 2 NV's Avatar
Default Re: already searched and found nothing. difference in 1.6 and 1.8 liter (rdeezy78)
its a silly question but not coming from a newbie. the B16 and B18 all share a 81mm bore, the extra displacement comes from the stroke of the crank.
Old May 14, 2007 | 06:18 PM
rdeezy78's Avatar
Default Re: already searched and found nothing. difference in 1.6 and 1.8 liter (1 2 NV)
so even though it has a larger bore, it still is a 1.8. I kinda thought that but I couldn't find in the search the stroke differences from a b16 and b18. Thanks
Old May 14, 2007 | 06:20 PM
Combustion Contraption's Avatar
Engine Code: Bore x Stroke
B16A 81 x 77
B18A 81 x 89
B18C1/C5 81 x 87.2
B20B/Z 84 x 89
1 2 NV's Avatar
if you increase bore you increase displacement too. im just telling you the difference between the B16 and B18. lets take an LS motor its got a 89mm crank displaces something like 1834cc and then take a B20 its got the same 89 mm crank but displaces 1996 if i remember right. same stroke different bore.
Old May 14, 2007 | 06:24 PM
rdeezy78's Avatar
gotcha good reference combustion. Thanks
Old May 14, 2007 | 07:25 PM
RPRacing's Avatar
you picked some good guys to get the info from any other questions?
scooterbuilteh2
Sep 17, 2009 02:31 PM
solo227
Sep 8, 2009 11:21 PM
MKcrxB16
25
Jul 20, 2006 11:36 AM
rtiadnoh
Feb 14, 2004 05:09 PM
oday
Sep 28, 2003 08:34 PM
