are all 92-00 sohc civic water pump inlet pipe the same?
are all 92-00 sohc civic water pump inlet pipe the same? if you don't know what im talking about it's the metal pipe the connects your thremostat housing to the block of the water pump.
This post is old but no they are not. Different part numbers. 92-95 are different from 96-00. They will both fit on each other though for instance i had a 5th gen pipe on my y8 block, the only real diference is the location of where u plug in the rubber hose on the pipe
Edgar Cruz
Honda Civic (2001 - 2005)
Dec 18, 2015 06:18 PM
sasinorm01
Feb 15, 2011 06:08 PM
