overheating problem.. top hose is hot bottom is cold
Old May 14, 2007 | 05:19 PM
blinger's Avatar
Default overheating problem.. top hose is hot bottom is cold
The housing that holds the thermostat is to hot to touch but yet the hose coming from it is cold... There is no thermostat in the unit so its not the thermostat being dumb ... what else could cause this? I havent had a problem with the car overheating at all until after I cleaned the IACV and FITV.
Old May 14, 2007 | 05:21 PM
turbo93da's Avatar
Default Re: overheating problem.. top hose is hot bottom is cold (blinger)
did you bleed out the coolant air pockets
and i would recomend a thermostat be in there
Old May 14, 2007 | 05:22 PM
91ed9's Avatar
radiator is probably clogged or the hose is clogged
sometihgn is not letting water through and its either the lower rad hose or the rad itself
Old May 14, 2007 | 05:36 PM
blinger's Avatar
Default Re: overheating problem.. top hose is hot bottom is cold (turbo93da)
yea .. had an overheating problem a few weeks ago.. took the thermo out and it fixed it.. car ran great til tonight when I cleaned the IACV and FITV. I'll be replacing it sometime this week.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbo93da &raquo;</TD></TR><TR><TD CLASS="quote">did you bleed out the coolant air pockets
and i would recomend a thermostat be in there</TD></TR></TABLE>
I took the cap off the radiator and let it run .. I couldn't find the bleeder screw on the thermostat housing tho. I seen a diagram of where it should be but couldn't see it.
Old May 14, 2007 | 05:45 PM
blinger's Avatar
took the bottom hose off where its connected to the thermostat and the housing was completely dry.
Old May 14, 2007 | 06:39 PM
blinger's Avatar
fixed..
retard mistake of forgetting to refill it with coolant
93grayeg
Jan 19, 2010 08:41 AM
d16trexin
Mar 23, 2009 05:54 AM
MrViet
Aug 30, 2008 02:31 PM
EM2ner
Honda Civic (2001 - 2005)
17
Jan 14, 2008 06:23 PM
snowblind7x
Feb 21, 2007 08:58 PM
