Just got my new header today!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mickeh »</TD></TR><TR><TD CLASS="quote">runnin the same headers on my teg
compliments of whitfield racing (rage)</TD></TR></TABLE>
you can get more than one header on a teg?
compliments of whitfield racing (rage)</TD></TR></TABLE>you can get more than one header on a teg?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tartje »</TD></TR><TR><TD CLASS="quote">
you can get more than one header on a teg?</TD></TR></TABLE>
V8 swap
I heard there are clearance issues if you're dumped.
Pics of the ground clearance if possible once you get it installed. Good Buy!
V8 swap
I went to their website and it says it does not fit a Type R.
"ALSO WILL NOT FIT... a factory Type R trans/motor brace, trans brace can be swapped with GSR/LS/B20. (modifications required by purchaser to fit properly). "
Are you planning to make those mods and then fit the header?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTW DC2R »</TD></TR><TR><TD CLASS="quote">is that an O2 bung on one of the runners???</TD></TR></TABLE>
Yes. Since the header is longer than stock, the primary O2 often will not reach to the collector without extending the wires. I assume positioning the bung there was done to eliminate the need for extending the O2 wiring. I recall that Hytech and several other long-tube designs positioned the bung there, so it's not surprising that the "replica" does too.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smoothe »</TD></TR><TR><TD CLASS="quote">
Pics of the ground clearance if possible once you get it installed. Good Buy!</TD></TR></TABLE>
Ehh, clearance isn't the greatest, but I haven't had any huge problems. I've been driving on mine for about 4-5 months and the pipes at the lowest section are barely scraped, and I think it was because I drove over a clump of dried cement.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by erasa510 »</TD></TR><TR><TD CLASS="quote">I heard the same with the tranny brace. Is this true? Can anyone confirm?</TD></TR></TABLE>
Won't fit with the ITR tranny brace. Just them with the 2 smaller braces from a gsr/b16 (i think). The brace also serves as a flywheel cover, so I've just been running with the flywheel cover from a b16 as a substitute.
hi, sorry yes it's the rage production header.
and yes it will not clear the itr tranny brace and i am thinking about using the tranny brace from a b16, which will/should help solve the problem.
I really want to get it install, but gotta have to wait around 2 weeks since my mechanic can only do it on weekends but i am a really busy this coming weekend, so hopefully next weekend i will have it installed and i will post pics for those who want to see the clearance.
anyone selling an extra gsr/ b16 tranny brace? I have the same headers but never got it install because i am still waitin for my jdm cat..now i guess i gotta wait on the tranny brace also. Pm me please
