Intake valves dirty???
Old May 14, 2007 | 03:21 PM
JLefevers's Avatar
Default Intake valves dirty???
ok been about 9,000 miles into this motor after i had fresh head work done. i changed the clutch and decided to pull the head and check everything out. when i looked at the valves the exahust still look like the day i put the head on but the intake valves are dirty as hell. i was wondering if this could be a sign of timing being too advanced? i always thought that the intake valves was supposed to be cleaner than the exahust. so any help would be great b/c this really has me wondering what was going on. Also the motor always ran fine and never studard but it did seem to lose power up higher in the rpm range but i was thinking it was the clutch slipping. Could lose of power in high rpm be timing to advanced????
Old May 14, 2007 | 03:40 PM
Ermil's Avatar
Default Re: Intake valves dirty??? (JLefevers)
What kind of gas do you run?
Old May 14, 2007 | 04:38 PM
JLefevers's Avatar
Default Re: Intake valves dirty??? (Ermil)
i always ran 93
Old May 14, 2007 | 05:50 PM
Crx Jimmy's Avatar
The intake side are always more dirty then the exhaust, the fuel sprays on them and you usually get some carbon buildup on them
Old May 15, 2007 | 03:31 AM
JLefevers's Avatar
Default Re: Intake valves dirty??? (Crx Jimmy)
ok thanx for the info
94lsrhd
Jun 13, 2009 05:55 PM
sup3rd
Nov 26, 2007 06:30 PM
zx2gotboost
11
Dec 22, 2005 01:52 PM
ChaosUnbound
Jul 17, 2003 03:29 PM
Speedz
Jan 24, 2002 04:54 PM
