GAS on 6th gen sedan
Old May 14, 2007 | 03:09 PM
power11's Avatar
Default GAS on 6th gen sedan
which gas do you really need to put in. 87 or 89, its a pure stock car with nothing done to it.
Old May 14, 2007 | 04:23 PM
tugboatonm's Avatar
Default Re: GAS on 6th gen sedan (power11)
regular.
no need to put high octain in a stock car
Old May 14, 2007 | 04:27 PM
YeuEmMaiMai's Avatar
87 octane or 85 in denver type elevations. anything higher than 87 is a waste ans will reduce power output
Old May 14, 2007 | 06:40 PM
skingfreak's Avatar
Default Re: GAS on 6th gen sedan (YeuEmMaiMai)
Not to be a thread *****, but how come you will lose power by putting in a hight octane?
Old May 14, 2007 | 07:55 PM
Heat's Avatar
Per the owner's manual on my '99 LX sedan, page 156:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Gasoline
Your Honda is designed to operate on unleaded gasoline with a pump octane number of 86 or higher. Use of a lower octane gasoline can cause a persistent, heavy metallic rapping noise in the engine that can lead to mechanical damage...</TD></TR></TABLE>
Old May 14, 2007 | 08:26 PM
Default Re: GAS on 6th gen sedan (skingfreak)
higher octane fuel is more resistant to detonation and burns slower so one has to adjust the timing approperiately. The J30a lacks a knock sensor and the I4 cannot use it to advance the timing when you put in higher octane fuel.
SlowEJ8
48
May 2, 2009 06:44 AM
extracrunchie
Jul 5, 2008 07:53 PM
caleb
Sep 7, 2003 06:57 AM
wm5holla
Jan 5, 2003 06:59 AM
DrAwoH
May 17, 2002 06:36 AM
