A very delicate and complicated VC spray job....
Old May 14, 2007 | 01:32 PM
HOCSA's Avatar
Default A very delicate and complicated VC spray job....
Hi all,
I am planning on painting the Kamikaze symbol on my D16 valve cover... This has probably been asked before, but I'm gonna ask it again...
Like this:
WITHOUT having to strip the VC or use expensive cleaners, what is the best and easiest way to mask off the VC to spray on the design? It should be fairly difficult because the VC is finished in crinkle paint...
This is what my car should look like once I'm done: (yes it's not the best photochop I know )
Old May 14, 2007 | 01:36 PM
kleen98accord's Avatar
Default Re: A very delicate and complicated VC spray job.... (HOCSA)
mask it with either the blue or green painters tape. you sould also pull the tape off when you finish painting becuase you don't want it to dry on your tape and when you peel it off, you peel some paint off too.
thats very interesting way of painting a valve cover. never seem anything like that.
Old May 15, 2007 | 06:49 PM
DesioMedia's Avatar
Aircraft remover is your friend. The stuff is cheap and works like magic. Just spray it on and let it do its thing. Then wipe the VC down, spray with a couple coats of white or almond (you can use either but I like the almond better). Then tape it off spray the red and polish.
Good luck
Old May 16, 2007 | 04:02 PM
95ProjectEJ1's Avatar
Default Re:
I like that VC... looks nice. I was thinking something like that for mine, it helps to justify the theme if you are part/full Japanese. All white with the Rising Sun would be pretty cool too
Old May 17, 2007 | 07:22 PM
phatboycrxhf's Avatar
Default Re: Re: (95ProjectEJ1)
buy a $20.00 sandblaster from walmart and go to town ,mine works great and strips that wrinkle paint right off
here is a pic of mine ,hasent been buffed yet but you get the point
and a pic of a manifold i stripped the hit with a buffer
before
after
i guess i should have asked if you had a air compressor
Old May 17, 2007 | 09:57 PM
B_CRUZ!'s Avatar
Default Re: Re: (phatboycrxhf)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phatboycrxhf &raquo;</TD></TR><TR><TD CLASS="quote">buy a $20.00 sandblaster from walmart </TD></TR></TABLE>
link?
Old May 18, 2007 | 01:35 AM
Default Re: Re: (B_Cruz)
sure thing ,i sandblasted the hole underside of my crx and the interior wheelwells everything lol many parts ,my valve cover lots of stuff ,but make sure when buying this sucker you get a inline air filter ,it doesnt work very well with water in the line lol
this is just a link of the one i have but ,i got mine at walmart ans couldent find it in the there site ,but it can be picked up at any harwre store
http://www.aircompressorsdirec...d=315
highliner82
18
Dec 7, 2010 05:50 PM
4twenty_CRX
32
Jul 17, 2007 09:34 PM
mountaindewguy
Mar 9, 2005 06:37 PM
cam003
Feb 24, 2004 11:14 PM
turbohf
Jul 2, 2002 03:01 PM
