Tire related VSS questions
Old May 14, 2007 | 09:59 AM
96GSRcx's Avatar
Default Tire related VSS questions
I have a general question which I know someone should be able to answer. I'll start with an example. The new Civic Si comes with 215/45-17 wheels/tires, but you can upgrade to 215/40-18 wheels/tires. Does the Vehicle Speed Sensor change to make up for the increase in rolling diameter? If it doesn't, Is there any calibration for the speedo? Is the VSS responsible for any/all calibration? Thanks
Old May 14, 2007 | 03:51 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: Tire related VSS questions (96GSRcx)
The difference in outer diameter between those two sizes is only about 0.6 percent, so there is no need for any change in the speed sensor or in the calibration of the speedometer.
By comparison, the difference in outer diameter between a tire that is brand new, and one that is worn and ready for replacement, is about 2.0 percent. So there is always the possibility of a little bit of error, beyond what you can calibrate for.
The 0.6 percent difference between those two tire sizes is too small to worry about.
Old May 14, 2007 | 05:28 PM
96GSRcx's Avatar
Default Re: Tire related VSS questions (nsxtasy)
At what point would you say the VSS/ speedometer would need to be recalibrated? And is that possible?
Old May 15, 2007 | 05:21 AM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96GSRcx &raquo;</TD></TR><TR><TD CLASS="quote">At what point would you say the VSS/ speedometer would need to be recalibrated?</TD></TR></TABLE>
It's at a point where you shouldn't be using that tire size.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96GSRcx &raquo;</TD></TR><TR><TD CLASS="quote">And is that possible?</TD></TR></TABLE>
I don't know.
justin2386
Apr 15, 2009 05:20 PM
B18C_EJ8
Jan 24, 2007 11:19 AM
Jasoncham2003
Sep 27, 2005 07:30 PM
DC2IntegraTypeR
Mar 18, 2004 04:36 PM
onyx00
Nov 2, 2003 01:30 AM
