OBD0 to OBD1 swap no start
Old May 14, 2007 | 09:58 AM
93formula's Avatar
Default OBD0 to OBD1 swap no start
i have a crx si did the obd1 swap with a b20 with a b18 head, came out of a running ef, car wont start.
have spark, when plugs are pulled can smell the fuel.
when it does start it runs for half a second then dies, using the vtec frog harness, go to check the engine light by grounding out the service check connector the engine light just stays on.
did the correct dizzy pin swap, havent connected the heated o2 yet, will that cause the car to not start? just want to see it run.
Old May 14, 2007 | 10:45 AM
93formula's Avatar
Default Re: OBD0 to OBD1 swap no start (93formula)
okay pulled the rail, attempted to start to see if the injectors were firing, they arent, fuel in the rail though.
Old May 14, 2007 | 11:55 AM
ludesrv's Avatar
You aren't using the connector right. You don't ground it, your bridge it. Stick a wire from one side to the other side of the same plugs (2 wire plug). It will flash cause it does it mine.
Of course, it will only flash if the proper wire is going to the proper pin on the ECU. In other words, your conversion has to be correct.
Old May 14, 2007 | 12:08 PM
93formula's Avatar
well i used the crx harness, repinned the dizzy as per instructions found on honda tech, and am using a 92 teg pr4 ecu with a vtec frog jumper harness, the vtecfrog instructions online state that you ground the yellow wire to read the service codes, am i doing something wrong?
Old May 14, 2007 | 01:20 PM
ludesrv's Avatar
Default Re: (93formula)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93formula &raquo;</TD></TR><TR><TD CLASS="quote">well i used the crx harness, repinned the dizzy as per instructions found on honda tech, and am using a 92 teg pr4 ecu with a vtec frog jumper harness, the vtecfrog instructions online state that you ground the yellow wire to read the service codes, am i doing something wrong?</TD></TR></TABLE>
Yes. You need to look under your dash, on the right side of the clove box. There will be a 2 pin service connector taped to your harness, remove the tape and jump the plug. The light will blink.
Old May 15, 2007 | 10:19 AM
93formula's Avatar
Default Re: (ludesrv)
okay thanks i will look for it there, just confusing some posting say its in the engine bay on the shock towers etc.
BTW it was a blown ecu fuse, lol. car starts now.
Old May 15, 2007 | 10:45 AM
93formula's Avatar
okay i found that connector, but i jumped it and the engine light goes away when i put the key in the on position. and the engine light comes back with the car on.
Old May 15, 2007 | 11:46 AM
93formula's Avatar
update: i was given a boomslang harness not a vteg frog.
1stgenboost
Jan 16, 2013 02:10 PM
CrxGrin
Dec 21, 2012 09:54 AM
EF8DayDreamer
14
Oct 26, 2012 02:01 PM
FOMULA91
Aug 13, 2008 05:17 AM
95_red_dc
Apr 18, 2006 07:58 PM
