best way to do piston/valve clearance???
Old May 14, 2007 | 08:43 AM
1PT-SICK's Avatar
Default best way to do piston/valve clearance???
im gonna be putting together my engine soon and im kinda worried cause my head was decked .030 i have low compression pistons but i still wanna check the clearances.....whats the best way to do this? i know i gotta put some playdough in the piston but whats the best way to turn it over cause i should probably check it when its in Vtec right? let me know......im trying to find out what size head gasket to get.......any help appreciated.
Old May 14, 2007 | 05:49 PM
fast forward driver's Avatar
Default Re: best way to do piston/valve clearance??? (1PT-SICK)
? engine are we talkin about , different engines have few different ways to engage for checking clearance, generally you can pull rockers apart and put some sort of spacer inside rocker with engagement pin, to lock together, , of course only need to do on one cylinder, and make shure to remove.
Old May 14, 2007 | 06:37 PM
NJIN BUILDR's Avatar
http://www.c-speedracing.com/h...y.php
Old May 15, 2007 | 06:25 AM
ITRnorway's Avatar
https://honda-tech.com/zerothread/1891614
Old May 15, 2007 | 05:11 PM
1PT-SICK's Avatar
thanks guys..... ....im gonna be trying this soon so we'll see whats up....if i have some questions ill ask. thanks again!
Old May 17, 2007 | 05:00 PM
1PT-SICK's Avatar
Default Re: best way to do piston/valve clearance??? (NJIN BUILDR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NJIN BUILDR &raquo;</TD></TR><TR><TD CLASS="quote">http://www.c-speedracing.com/h...y.php</TD></TR></TABLE>
i was reading over this and i dont understand when it says..... "switch the VTEC pistons in the rocker arms so that it locks the VTEC rocker in place"......there is three little VTEC pistons right? what do you switch? or can someone just explain that part??? i knew how to do everything else i just wanna know how to make it stay in VTEC. thanks.
spoolinvtec54
Engine Machining & Assembly
11
Nov 10, 2016 09:31 AM
PatrickGSR94
Jun 19, 2013 10:26 AM
95accord3267
Feb 28, 2012 12:03 PM
DougieFreshZero
Acura TSX
Jan 12, 2009 05:29 PM
Race Egr
Sep 16, 2003 01:46 PM
