Can I just replace one rod bearing?
Old May 14, 2007 | 08:35 AM
rextasy's Avatar
Default Can I just replace one rod bearing?
I was wondering if it was possible to only replace one rod bearing. All my bearings looked good except for one that has slight wear. I was going to replace all of them since I was there but the brown is back ordered for 2 weeks. If I have to, I will wait but if I can just replace the one that doesn't look 100% I'll be back on the road alot faster.
Thanks
Old May 14, 2007 | 10:01 AM
mahatma's Avatar
Default Re: Can I just replace one rod bearing? (rextasy)
you can definitely replace just one bearing, but it's likely that you'll re-spin it again if you don't at least replace that rod.
generally people say that the crank will be scarred from the heat and should also be replaced, but i guess everyone's carnage/aftermath is a little different....
Old May 14, 2007 | 10:05 AM
rextasy's Avatar
Default Re: Can I just replace one rod bearing? (mahatma)
I didn't spin a bearing yet but I was in the middle of replacing my rings and noticed that some of my bearing have darker areas is the best I can do to explain. It's like some of it has a film still on it and some areas don't. I thought I would replace them before I spun one.
Thanks
Old May 14, 2007 | 10:19 AM
dumped4dr's Avatar
yes u CAN just replace one bearing but it makes sense to do them all. but like mahatma said, u will probably run into the same problem later.
n/a_kong
Jul 2, 2010 06:52 AM
tdizz07
Oct 27, 2006 08:24 AM
IN VTEC
Nov 23, 2003 09:13 PM
Quiz
Jan 21, 2003 11:31 AM
