burning oil mess up a/f alot ?
Best way to tune a car with problems - make them fix the problems first. You shouldn't boost unless everything works 100%. Unless you have a DSM, as that's impossible.
Depending on how the O2 is mounted, it can be clogged with burnt oil residue. Since the sensors are very sensitive, it could cause an issue.
