wont go past 3.5, 4 rpm's
Old May 14, 2007 | 08:12 AM
GSR_hatch936's Avatar
Default wont go past 3.5, 4 rpm's
alright i got a 94 honda accord ex with a stock f22 sohc vtec 5sp and wen i step on the gas i drive good untill 3 or 4 rpm's and then i got to shift it to the next gear well anyone know if its the tranny or ecu or anyother thing that would give me this problem!! i had the headgasket fix a year ago and it never worked right after that!!!
Old May 14, 2007 | 08:21 AM
streetxdreamer's Avatar
Default Re: wont go past 3.5, 4 rpm's (GSR_hatch936)
i dont really understand what you are asking.
Old May 14, 2007 | 08:28 AM
Default Re: wont go past 3.5, 4 rpm's (streetxdreamer)
my bad if u cant understand but the car feels like it wont go anymore like if the car is gettin held back or somthing but this is only around the 3 or 4 rpm's and then i shift and it drives good till it get to 3 or 4 rpm's!!<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by streetxdreamer &raquo;</TD></TR><TR><TD CLASS="quote">i dont really understand what you are asking.</TD></TR></TABLE>
Old May 14, 2007 | 08:53 AM
white99CF's Avatar
one of my buddy s had the same problem wit his f22 accord it probably has somethin to do wit ecu/fuel cut out maybe,i do kno that one reason my buddies wouldnt run was because he had bad rings
Old May 14, 2007 | 09:03 AM
MaXiMuS1701's Avatar
sounds to me like th vtec is not kicking in, when i put in my vtec engine, i did not have the ECU for it yet, so the b2 ecu allowed that car to run but did not control the vtec, and thats what mine was doing when it did not hit vtec.
its ok until a little above 2.5 then the power band starts to run out and by the time your at 4 there is no power and the RPM is bouncing right. if so then i bet thats the problem.
Old May 14, 2007 | 10:30 AM
Default Re: wont go past 3.5, 4 rpm's (MaXiMuS1701)
well how do i get that checked?? or how would i know for sure its the ecu??
Old May 14, 2007 | 12:03 PM
notoriousB's Avatar
are you low on oil? if the motor is low on oil vtec will not engage.
Old May 14, 2007 | 02:03 PM
gosu08's Avatar
Default Re: wont go past 3.5, 4 rpm's (notoriousB)
did you check your spark plugs?
Old May 14, 2007 | 02:06 PM
tomcool's Avatar
I have the same problem with engine ligh on...it will improve after do the oil change
Old May 14, 2007 | 07:26 PM
Default Re: wont go past 3.5, 4 rpm's (tomcool)
i dont think its the vtec! cuz if it is it will still go past the 3.5 or 4 rpm's it wont go past that its like it wont accurlate after that but dont know wat it is!!!!
Old May 14, 2007 | 07:30 PM
Alpinestar03's Avatar
Deffinatly sounds like a dying fuel pump. You dont even have to drop the tank to change the fuel pump, unlike most cars.
-Eric
Old May 14, 2007 | 07:31 PM
lowered94accord's Avatar
vtec can engage at various times...just because your getting all the way to 3.5 to 4k rpms doesnt mean your vtec is engaging..check your oil and if its low thats the problem..i had that problem a while back when my car leaked oil horribly and when it got low vtec wouldnt engage and it wouldnt go past 4k
Old May 14, 2007 | 07:36 PM
98savage's Avatar
Default Re: wont go past 3.5, 4 rpm's (lowered94accord)
Hey man, it seems like you've had some pigshit luck with your car. You're in every thread having had the same problems. LOL.
Old May 14, 2007 | 07:53 PM
Default Re: wont go past 3.5, 4 rpm's (98savage)
yea i bought the accord like a year ago and felt like i need some power and bought the si hatch with a gsr but im having bad luck with cars!! but if anyone intrested in the accord email me at espinoza_69@hotmail.com ill post pics if yall wont but dont wanna get banned from here so just email me or something i got pics!!
Old May 14, 2007 | 09:57 PM
98savage's Avatar
Oh no, I was talking to loweredaccord...my bad bro.
Old May 14, 2007 | 10:07 PM
aint no problem!!!
Old May 16, 2007 | 08:07 AM
Eddiebx's Avatar
Default Re: (Alpinestar03)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Alpinestar03 &raquo;</TD></TR><TR><TD CLASS="quote">Deffinatly sounds like a dying fuel pump. You dont even have to drop the tank to change the fuel pump, unlike most cars.
-Eric</TD></TR></TABLE>
how do u change the fuel pump w/o dropping the tank, cut a hole under the rear seat?
Old May 16, 2007 | 08:51 AM
notoriousB's Avatar
Default Re: (Eddiebx)
there's an access panel in the trunk.
Old May 16, 2007 | 08:52 AM
Eddiebx's Avatar
Default Re: (notoriousB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by notoriousB &raquo;</TD></TR><TR><TD CLASS="quote">there's an access panel in the trunk. </TD></TR></TABLE>
you mean the access panel to the fuel LEVEL SENDER?
DnB TeK
Oct 1, 2007 09:58 AM
NovaKnowledgeNow
Apr 16, 2005 03:43 AM
Staats0778
Jan 12, 2005 06:01 AM
steve-o40
May 2, 2004 04:33 PM
HT Chaplain
Apr 22, 2004 05:06 PM
