ef hatch wheel rate
Old May 14, 2007 | 07:13 AM
gwiffer's Avatar
Default ef hatch wheel rate
Has anyone measured the motion ratio and calculated the corresponding wheel rate for the ef hatch? If not, I'll eventually get around to measuring it myself.
I just want to know if the front and rear ratios/rates are different?
I've heard that later model civics have a front wheel rate of 1.7.
Old May 14, 2007 | 09:03 AM
mahatma's Avatar
Default Re: ef hatch wheel rate (gwiffer)
what is wheel rate exactly?
Old May 14, 2007 | 05:38 PM
gwiffer's Avatar
Default Re: ef hatch wheel rate (mahatma)
http://www.miracerros.com/mustang/t_wheel_rate.htm
forget the stuff about mustangs
Old May 14, 2007 | 06:08 PM
Crx Jimmy's Avatar
what would you need to know the wheel rate for? Just up the spring rate till the car behaves like you want. What is your intent for the car?
89brokendownEF
Welding / Fabrication
Jun 7, 2014 11:58 AM
hyperblu
Sep 13, 2011 05:01 PM
JDMJAYDC2
Nov 5, 2007 12:53 PM
PIC Performance
Suspension & Brakes
27
May 27, 2005 11:11 AM
